Hardware AC Ryan Playon! DVR TV
Discussion in 'Article Discussion' started by Tim S, 25 Apr 2009.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. WildThing
    WildThing Minimodder
    26 Jul 2007
    This was looking really interesting until I read the bit about it not supporting .MKV's. Also, the fact that the NAS feature isn't that great is disappointing.
  3. dullonien
    dullonien Master of the unfinished.
    22 Dec 2005
    I'm using a IcyBox NAS4220-B for the storage and a Lynksis Kiss 1600 to access the media. Works well at the moment, due to the built in Twonky Media on the IcyBox. This set-up can't be directly compared to this AC Ryan, as it's lacking the TV functions, but it does offer more storage with space for 2 hard drives. Cost wise, this AC Ryan Playon! is good value imo, I think my setup cost over £200 + HD's.
    As soon as I have the time and money, I'll upgrade to a custom build MITX system to do what the Playon! does, it's the best route imo, especially as I have a spare Core2Duo and twin TV Card. Media Centre is also a big step up, OS wise. Both that AC Ryan Playon! and my Kiss 1600 user interfaces look ugly and limited. Support for all media files would also be straght forward. I've also filled my 1TB storage in the IcyBox, so more HD space, through larger drives or more of them is a must.
    Good review as always Bit.
  4. leexgx
    leexgx CPC hang out zone (i Fix pcs i do )
    28 Jun 2006
    no 1000 port . read it all when get home (no mkv support is an no for it unless i convert it)
  5. Xir
    Xir Modder
    26 Apr 2006
    Why the restriction to a "100MB/s Ethernet port" and not a 1000MB/s one...is it that much more expensive?
    (Same question goes for Netbooks really...with no drive to feed them with)
    I'd think when toying with DVD-sized files (especially since the file system is up to it) 100MB/s is a bit...limited
  6. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    Try replacing the harddrive with current Top-end SSD's and show us the results
    Pretty please :D
  7. Jenny_Y8S
    Jenny_Y8S Guest
    So it's a terrible HD player? It's a terrible NAS?
    Yeah 8/10 sounds a bit high to me
  8. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    No HD already killed it for me. Shame about the NAS function, too.
    Another good idea... another bad result. :sigh:
  9. Saivert
    Saivert Minimodder
    26 Mar 2005
    This product doesn't even deserve to be mentioned on Bit-tech. please delete the article and never speak of it again!
    No HD support in 2009? That is fail on a big level!
    I believe this is a victim of the current struggling economy. They try to push out sub-standard products that are cheap to manufacture (using outdated stuff) and looks attractive on the box. But when it's put through the scrutiny of this community it falls short immediately.
  10. The boy 4rm oz
    10 Apr 2008
    Looks pretty damn good to me. Personally I try to avoid .MKV files if I must, I prefer .AVI. I really like how you get to add your own HDD, makes it easier to get the right size for you.
  11. perplekks45
    9 May 2004
    Why do you avoid .MKV? I never had any problems with that container.
  12. The boy 4rm oz
    10 Apr 2008
    I just find .AVI to be better quality (both visually and audibly). .MKV may be a smaller file size but HDD space isn't something I am really concerned about.
  13. leexgx
    28 Jun 2006
    mkv files are 3x bigger (1.2gb tv 4.4gb 720p 8gb 1080p) then avi files norm you must of been getting converted xvid files
  14. Guest-16
    Guest-16 Guest
    God no. .Mkv is far more flexible in terms of both video and audio codecs and h/x.264 allows more advanced compression standards
  15. BigM2006
    BigM2006 What's a Dremel?
    8 May 2006
    I think its a bit feature lacking, given that its meant to replace a number of devices....
  16. shaffaaf27
    shaffaaf27 The budget builder
    3 Jun 2008
    will bit-tech be reviewing the Western Digital HD Media Player?
  17. The boy 4rm oz
    10 Apr 2008
    I was meant to write it the other way around lol, I was tired.
    Really it's just my personal preference. I have used both .AVI (including Xvid/DivX converts) and .MKV but .MKV always seems to find away to kick it's own arse. All my ventures with .MKV have ended badly lol .AVI is far less hassle for me.
  18. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    Like mentioned before, it was all a good read until the HD and NAS part. The interface looks outdated to. I also disagree with the high score it gets. It should have been all 5 and 7 for the looks...
  19. Stelph
    Stelph Minimodder
    24 Dec 2007
    Shame, a good first attempt I think but not quite enough yet in my opinion, what I would really like to see is the features that this has along with:
    1) An IR blaster so that it can control a seperate AV Box (if you wanted to use sky/freesat) or even a model with a DVB-S/S2 receiver built in
    2) stable and complete 720p and 1080i playback for all fiuletypes/bitrates, inexcusable really that it is missing this!
    3) A Bitorrent client built in (like the popcorn hour)
    Then it would be perfect!
  20. leexgx
    28 Jun 2006
    ops i agree with this user my self i do have far less problems with xvids as thay have been standered for last 5 or more years ,mkv do not all ways work well but 720p stuff is nice, seems to be better now then from yr or 2 ago
Tags: Add Tags
