Linux ACCESS VIOLATION SUMMARY (ati driver) & emake fail (links)
Discussion in 'Software' started by Woodstock, 24 May 2008.
  1. Woodstock
    Woodstock So Say We All
    10 Sep 2006
    hi, i just installed gentoo on my laptop, it has an ati graphics card so emerged (is that the right word) ati-drivers (which is the fglrx driver) but i get this ACCESS VIOLATION SUMMARY
    LOG FILE = "/var/log/sandbox/sandbox-x11-drivers_-_ati-drivers-8.471.3-19678.log"
    it then repets open_wr: /usr/src/linux-2.6.24-gentoo-r8/null.gcda (which is also the contents of the .log file) im a little unsure what im ment to do now
    i also tried emerging links but get this
    !!! ERROR: media-libs/tiff-3.8.2-r3 failed
    call stack
    ebuild.sh, line 1614 called dyn_compile
    ebuild.sh, line 971 called qa_call 'src_compile'
    enviroment, line 3471 called src_compile
    tiff-3.8.2-r3.ebuild, line 42 called die
    !!! emake failed
    !!! a complete build log is located at /var/tmp/portage/media-libs/tiff-3.8.2-r3/temp/build.log
    edit: just went to recompile the kernel to add support for my wireless nic and discovered that there is clock skew, which google has told me means that something todo with make happened at a future date, the date command returns a time that is about a minute different then my watch, strange that the handbook metioned enter the date command a couple of times which was fine then (differnce about the same as now) is this releated to those problems or just another one?
  2. Glider
    Glider /dev/null
    2 Aug 2005
    Try removing the temporary files in /var/tmp/portage and the source tarball in /usr/portage/distfiles.
    Then reemerge.
  3. Woodstock
    10 Sep 2006
    im guessing that would be for links, (who would have thought a browser on a machine with the error message could be useful) i think i may have found a soulution to the ati driver on the gentoo fourms ill give both a shot soonish
    edit
    got the same problem after your suggestion, and the other thing i tried involved emerge -aND world to which portage<version> is blocking bash<version> i tried locking bash to a max version below that but that didnt work
    edit2
    so got around the sandbox violation there was two options FEATURES="-sandbox" emerge ati-drivers or updating sandbox which worked, but X is not playing ball at all, could someone possible give me a working xorg.conf to modify?
  4. Fophillips
    Fophillips What's a Dremel?
    9 Oct 2006
    Look at the Gentoo Bugzilla for your problem, if it’s not there file a bug yourself. xorgconfig should help you get a working xorg.conf. Post the contents of Xorg.0.log here and I’ll take a look.
  5. Woodstock
    10 Sep 2006
    right worked when using aticonfig but x fails to start due to no input driver matching mouse of kbd
    Code:
    X Window System Version 1.3.0
    Release Date: 19 April 2007
    X Protocol Version 11, Revision 0, Release 1.3
    Build Operating System: UNKNOWN
    Current Operating System: Linux ronnie-laptop 2.6.24-gentoo-r8 #1 SMP Sat May 24 23:44:41 NZST 2008 x86_64
    Build Date: 24 May 2008
    	Before reporting problems, check http://wiki.x.org
    	to make sure that you have the latest version.
    Module Loader present
    Markers: (--) probed, (**) from config file, (==) default setting,
    	(++) from command line, (!!) notice, (II) informational,
    	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
    (==) Log file: "/var/log/Xorg.0.log", Time: Sun May 25 11:49:43 2008
    (==) Using config file: "/etc/X11/xorg.conf"
    (==) ServerLayout "aticonfig-Layout[all]"
    (**) |-->Screen "aticonfig-Screen[0]" (0)
    (**) |   |-->Monitor "aticonfig-Monitor[0]"
    (**) |   |-->Device "aticonfig-Device[0]"
    (==) |-->Input Device "<default pointer>"
    (==) |-->Input Device "Generic Keyboard"
    (WW) The core pointer device wasn't specified explicitly in the layout.
    	Using the default mouse configuration.
    (WW) The core keyboard device wasn't specified explicitly in the layout.
    	Using the first core keyboard device.
    (WW) The directory "/usr/share/fonts/TTF/" does not exist.
    	Entry deleted from font path.
    (WW) The directory "/usr/share/fonts/OTF" does not exist.
    (==) FontPath set to:
    	/usr/share/fonts/misc/,
    	/usr/share/fonts/Type1/,
    	/usr/share/fonts/100dpi/,
    	/usr/share/fonts/75dpi/
    (==) RgbPath set to "/usr/share/X11/rgb"
    (==) ModulePath set to "/usr/lib64/xorg/modules"
    (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
    (II) No APM support in BIOS or kernel
    (II) Loader magic: 0x6ace20
    (II) Module ABI versions:
    	X.Org ANSI C Emulation: 0.3
    	X.Org Video Driver: 1.2
    	X.Org XInput driver : 0.7
    	X.Org Server Extension : 0.3
    	X.Org Font Renderer : 0.5
    (II) Loader running on linux
    (II) LoadModule: "pcidata"
    (II) Loading /usr/lib64/xorg/modules//libpcidata.so
    (II) Module pcidata: vendor="X.Org Foundation"
    	compiled for 1.3.0, module version = 1.0.0
    	ABI class: X.Org Video Driver, version 1.2
    (--) using VT number 7
    (II) PCI: PCI scan (all values are in hex)
    (II) PCI: 00:00:0: chip 8086,27a0 card 1043,1317 rev 03 class 06,00,00 hdr 00
    (II) PCI: 00:01:0: chip 8086,27a1 card 0000,0000 rev 03 class 06,04,00 hdr 01
    (II) PCI: 00:1b:0: chip 8086,27d8 card 1043,1339 rev 02 class 04,03,00 hdr 00
    (II) PCI: 00:1c:0: chip 8086,27d0 card 0000,0000 rev 02 class 06,04,00 hdr 81
    (II) PCI: 00:1c:1: chip 8086,27d2 card 0000,0000 rev 02 class 06,04,00 hdr 81
    (II) PCI: 00:1c:2: chip 8086,27d4 card 0000,0000 rev 02 class 06,04,00 hdr 81
    (II) PCI: 00:1d:0: chip 8086,27c8 card 1043,1317 rev 02 class 0c,03,00 hdr 80
    (II) PCI: 00:1d:1: chip 8086,27c9 card 1043,1317 rev 02 class 0c,03,00 hdr 00
    (II) PCI: 00:1d:2: chip 8086,27ca card 1043,1317 rev 02 class 0c,03,00 hdr 00
    (II) PCI: 00:1d:3: chip 8086,27cb card 1043,1317 rev 02 class 0c,03,00 hdr 00
    (II) PCI: 00:1d:7: chip 8086,27cc card 1043,1317 rev 02 class 0c,03,20 hdr 00
    (II) PCI: 00:1e:0: chip 8086,2448 card 0000,0000 rev e2 class 06,04,01 hdr 01
    (II) PCI: 00:1f:0: chip 8086,27b9 card 1043,1317 rev 02 class 06,01,00 hdr 80
    (II) PCI: 00:1f:2: chip 8086,27c4 card 1043,1317 rev 02 class 01,01,80 hdr 00
    (II) PCI: 00:1f:3: chip 8086,27da card 1043,1317 rev 02 class 0c,05,00 hdr 00
    (II) PCI: 01:00:0: chip 1002,71d5 card 1043,1242 rev 00 class 03,00,00 hdr 00
    (II) PCI: 02:00:0: chip 10ec,8168 card 1043,11f5 rev 01 class 02,00,00 hdr 00
    (II) PCI: 03:00:0: chip 8086,4222 card 8086,1001 rev 02 class 02,80,00 hdr 00
    (II) PCI: 06:01:0: chip 1180,0832 card 1043,1317 rev 00 class 0c,00,10 hdr 80
    (II) PCI: 06:01:1: chip 1180,0822 card 1043,1317 rev 19 class 08,05,00 hdr 80
    (II) PCI: 06:01:2: chip 1180,0843 card 1043,1317 rev 01 class 08,80,00 hdr 80
    (II) PCI: 06:01:3: chip 1180,0592 card 1043,1317 rev 0a class 08,80,00 hdr 80
    (II) PCI: End of PCI scan
    (II) Intel Bridge workaround enabled
    (II) Host-to-PCI bridge:
    (II) Bus 0: bridge is at (0:0:0), (0,0,6), BCTRL: 0x0008 (VGA_EN is set)
    (II) Bus 0 I/O range:
    	[0] -1	0	0x00000000 - 0x0000ffff (0x10000) IX[B]
    (II) Bus 0 non-prefetchable memory range:
    	[0] -1	0	0x00000000 - 0xffffffff (0x100000000) MX[B]
    (II) Bus 0 prefetchable memory range:
    (II) PCI-to-PCI bridge:
    (II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x000a (VGA_EN is set)
    (II) Bus 1 I/O range:
    	[0] -1	0	0x00009000 - 0x0000bfff (0x3000) IX[B]
    (II) Bus 1 non-prefetchable memory range:
    	[0] -1	0	0xfdf00000 - 0xfdffffff (0x100000) MX[B]
    (II) Bus 1 prefetchable memory range:
    	[0] -1	0	0xbdf00000 - 0xddefffff (0x20000000) MX[B]
    (II) Bus 2: bridge is at (0:28:0), (0,2,2), BCTRL: 0x0002 (VGA_EN is cleared)
    (II) Bus 2 I/O range:
    	[0] -1	0	0x0000c000 - 0x0000cfff (0x1000) IX[B]
    (II) Bus 2 non-prefetchable memory range:
    	[0] -1	0	0xfe000000 - 0xfe0fffff (0x100000) MX[B]
    (II) Bus 3: bridge is at (0:28:1), (0,3,3), BCTRL: 0x0002 (VGA_EN is cleared)
    (II) Bus 3 non-prefetchable memory range:
    	[0] -1	0	0xfe100000 - 0xfe1fffff (0x100000) MX[B]
    (II) Bus 4: bridge is at (0:28:2), (0,4,5), BCTRL: 0x0002 (VGA_EN is cleared)
    (II) Bus 4 I/O range:
    	[0] -1	0	0x0000d000 - 0x0000dfff (0x1000) IX[B]
    (II) Bus 4 non-prefetchable memory range:
    	[0] -1	0	0xfe200000 - 0xfe9fffff (0x800000) MX[B]
    (II) Bus 4 prefetchable memory range:
    	[0] -1	0	0xddf00000 - 0xdfefffff (0x2000000) MX[B]
    (II) Subtractive PCI-to-PCI bridge:
    (II) Bus 6: bridge is at (0:30:0), (0,6,6), BCTRL: 0x0002 (VGA_EN is cleared)
    (II) Bus 6 non-prefetchable memory range:
    	[0] -1	0	0xfea00000 - 0xfeafffff (0x100000) MX[B]
    (II) PCI-to-ISA bridge:
    (II) Bus -1: bridge is at (0:31:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
    (--) PCI:*(1:0:0) ATI Technologies Inc M66-P ATI Mobility Radeon X1700 rev 0, Mem @ 0xc0000000/28, 0xfdff0000/16, I/O @ 0xb000/8, BIOS @ 0xfdfc0000/17
    (II) Addressable bus resource ranges are
    	[1] -1	0	0x00000000 - 0x0000ffff (0x10000) IX[B]
    (II) OS-reported resource ranges:
    	[0] -1	0	0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
    	[1] -1	0	0x000f0000 - 0x000fffff (0x10000) MX[B]
    	[2] -1	0	0x000c0000 - 0x000effff (0x30000) MX[B]
    	[3] -1	0	0x00000000 - 0x0009ffff (0xa0000) MX[B]
    	[4] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[B]
    	[5] -1	0	0x00000000 - 0x000000ff (0x100) IX[B]
    (II) Active PCI resource ranges:
    	[0] -1	0	0xfeafec00 - 0xfeafecff (0x100) MX[B]
    	[1] -1	0	0xfeaff000 - 0xfeaff0ff (0x100) MX[B]
    	[2] -1	0	0xfeaff400 - 0xfeaff4ff (0x100) MX[B]
    	[3] -1	0	0xfeaff800 - 0xfeafffff (0x800) MX[B]
    	[4] -1	0	0xfe1ff000 - 0xfe1fffff (0x1000) MX[B]
    	[5] -1	0	0xfe0ff000 - 0xfe0fffff (0x1000) MX[B]
    	[6] -1	0	0xfebfbc00 - 0xfebfbfff (0x400) MX[B]
    	[7] -1	0	0xfebfc000 - 0xfebfffff (0x4000) MX[B]
    	[8] -1	0	0xfdfc0000 - 0xfdfdffff (0x20000) MX[B](B)
    	[9] -1	0	0xfdff0000 - 0xfdffffff (0x10000) MX[B](B)
    	[10] -1	0	0xc0000000 - 0xcfffffff (0x10000000) MX[B](B)
    	[11] -1	0	0x0000c800 - 0x0000c8ff (0x100) IX[B]
    	[12] -1	0	0x00000400 - 0x0000041f (0x20) IX[B]
    	[13] -1	0	0x0000ffa0 - 0x0000ffaf (0x10) IX[B]
    	[14] -1	0	0x000001f0 - 0x000001f0 (0x1) IX[B]
    	[15] -1	0	0x000001f0 - 0x000001f7 (0x8) IX[B]
    	[16] -1	0	0x000001f0 - 0x000001f0 (0x1) IX[B]
    	[17] -1	0	0x000001f0 - 0x000001f7 (0x8) IX[B]
    	[18] -1	0	0x0000e480 - 0x0000e49f (0x20) IX[B]
    	[19] -1	0	0x0000e800 - 0x0000e81f (0x20) IX[B]
    	[20] -1	0	0x0000e880 - 0x0000e89f (0x20) IX[B]
    	[21] -1	0	0x0000ec00 - 0x0000ec1f (0x20) IX[B]
    	[22] -1	0	0x0000b000 - 0x0000b0ff (0x100) IX[B](B)
    (II) Active PCI resource ranges after removing overlaps:
    (II) OS-reported resource ranges after removing overlaps with PCI:
    (II) All system resource ranges:
    	[4] -1	0	0xfeafec00 - 0xfeafecff (0x100) MX[B]
    	[5] -1	0	0xfeaff000 - 0xfeaff0ff (0x100) MX[B]
    	[6] -1	0	0xfeaff400 - 0xfeaff4ff (0x100) MX[B]
    	[7] -1	0	0xfeaff800 - 0xfeafffff (0x800) MX[B]
    	[8] -1	0	0xfe1ff000 - 0xfe1fffff (0x1000) MX[B]
    	[9] -1	0	0xfe0ff000 - 0xfe0fffff (0x1000) MX[B]
    	[10] -1	0	0xfebfbc00 - 0xfebfbfff (0x400) MX[B]
    	[11] -1	0	0xfebfc000 - 0xfebfffff (0x4000) MX[B]
    	[12] -1	0	0xfdfc0000 - 0xfdfdffff (0x20000) MX[B](B)
    	[13] -1	0	0xfdff0000 - 0xfdffffff (0x10000) MX[B](B)
    	[14] -1	0	0xc0000000 - 0xcfffffff (0x10000000) MX[B](B)
    	[15] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[B]
    	[16] -1	0	0x00000000 - 0x000000ff (0x100) IX[B]
    	[17] -1	0	0x0000c800 - 0x0000c8ff (0x100) IX[B]
    	[18] -1	0	0x00000400 - 0x0000041f (0x20) IX[B]
    	[19] -1	0	0x0000ffa0 - 0x0000ffaf (0x10) IX[B]
    	[20] -1	0	0x000001f0 - 0x000001f0 (0x1) IX[B]
    	[21] -1	0	0x000001f0 - 0x000001f7 (0x8) IX[B]
    	[22] -1	0	0x000001f0 - 0x000001f0 (0x1) IX[B]
    	[23] -1	0	0x000001f0 - 0x000001f7 (0x8) IX[B]
    	[24] -1	0	0x0000e480 - 0x0000e49f (0x20) IX[B]
    	[25] -1	0	0x0000e800 - 0x0000e81f (0x20) IX[B]
    	[26] -1	0	0x0000e880 - 0x0000e89f (0x20) IX[B]
    	[27] -1	0	0x0000ec00 - 0x0000ec1f (0x20) IX[B]
    	[28] -1	0	0x0000b000 - 0x0000b0ff (0x100) IX[B](B)
    (II) LoadModule: "extmod"
    (II) Loading /usr/lib64/xorg/modules/extensions//libextmod.so
    (II) Module extmod: vendor="X.Org Foundation"
    	Module class: X.Org Server Extension
    	ABI class: X.Org Server Extension, version 0.3
    (II) Loading extension SHAPE
    (II) Loading extension MIT-SUNDRY-NONSTANDARD
    (II) Loading extension BIG-REQUESTS
    (II) Loading extension SYNC
    (II) Loading extension MIT-SCREEN-SAVER
    (II) Loading extension XC-MISC
    (II) Loading extension XFree86-VidModeExtension
    (II) Loading extension XFree86-Misc
    (II) Loading extension XFree86-DGA
    (II) Loading extension DPMS
    (II) Loading extension TOG-CUP
    (II) Loading extension Extended-Visual-Information
    (II) Loading extension XVideo
    (II) Loading extension XVideo-MotionCompensation
    (II) Loading extension X-Resource
    (II) LoadModule: "dbe"
    (II) Loading /usr/lib64/xorg/modules/extensions//libdbe.so
    (II) Module dbe: vendor="X.Org Foundation"
    (II) Loading extension DOUBLE-BUFFER
    (II) LoadModule: "glx"
    (II) Loading /usr/lib64/xorg/modules/extensions//libglx.so
    (II) Module glx: vendor="X.Org Foundation"
    (==) AIGLX enabled
    (II) Loading extension GLX
    (II) LoadModule: "freetype"
    (II) Loading /usr/lib64/xorg/modules/fonts//libfreetype.so
    (II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
    	compiled for 1.3.0, module version = 2.1.0
    	Module class: X.Org Font Renderer
    	ABI class: X.Org Font Renderer, version 0.5
    (II) Loading font FreeType
    (II) LoadModule: "type1"
    (II) Loading /usr/lib64/xorg/modules/fonts//libtype1.so
    (II) Module type1: vendor="X.Org Foundation"
    	compiled for 1.3.0, module version = 1.0.2
    (II) Loading font Type1
    (II) LoadModule: "record"
    (II) Loading /usr/lib64/xorg/modules/extensions//librecord.so
    (II) Module record: vendor="X.Org Foundation"
    	compiled for 1.3.0, module version = 1.13.0
    (II) Loading extension RECORD
    (II) LoadModule: "dri"
    (II) Loading /usr/lib64/xorg/modules/extensions//libdri.so
    (II) Module dri: vendor="X.Org Foundation"
    (II) Loading extension XFree86-DRI
    (II) LoadModule: "fglrx"
    (II) Loading /usr/lib64/xorg/modules//drivers/fglrx_drv.so
    (II) Module fglrx: vendor="FireGL - ATI Technologies Inc."
    	compiled for 7.1.0, module version = 8.47.3
    	Module class: X.Org Video Driver
    (II) LoadModule: "mouse"
    (WW) Warning, couldn't open module mouse
    (II) UnloadModule: "mouse"
    (EE) Failed to load module "mouse" (module does not exist, 0)
    (II) LoadModule: "kbd"
    (WW) Warning, couldn't open module kbd
    (II) UnloadModule: "kbd"
    (EE) Failed to load module "kbd" (module does not exist, 0)
    (II) Primary Device is: PCI 01:00:0
    (II) ATI Proprietary Linux Driver Version Identifier:8.47.3
    (II) ATI Proprietary Linux Driver Release Identifier: UNSUPPORTED-8.476
    (II) ATI Proprietary Linux Driver Build Date: Mar 29 2008 00:05:57
    (--) Assigning device section with no busID to primary device
    (--) Chipset Supported AMD Graphics Processor (0x71D5) found
    (II) AMD Video driver is running on a device belonging to a group targeted for this release
    (II) AMD Video driver is signed
    (II) resource ranges after xf86ClaimFixedResources() call:
    (II) fglrx(0): pEnt->device->identifier=0x6d12f0
    (II) resource ranges after probing:
    	[15] 0	0	0x000a0000 - 0x000affff (0x10000) MS[B]
    	[16] 0	0	0x000b0000 - 0x000b7fff (0x8000) MS[B]
    	[17] 0	0	0x000b8000 - 0x000bffff (0x8000) MS[B]
    	[18] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[B]
    	[19] -1	0	0x00000000 - 0x000000ff (0x100) IX[B]
    	[20] -1	0	0x0000c800 - 0x0000c8ff (0x100) IX[B]
    	[21] -1	0	0x00000400 - 0x0000041f (0x20) IX[B]
    	[22] -1	0	0x0000ffa0 - 0x0000ffaf (0x10) IX[B]
    	[23] -1	0	0x000001f0 - 0x000001f0 (0x1) IX[B]
    	[24] -1	0	0x000001f0 - 0x000001f7 (0x8) IX[B]
    	[25] -1	0	0x000001f0 - 0x000001f0 (0x1) IX[B]
    	[26] -1	0	0x000001f0 - 0x000001f7 (0x8) IX[B]
    	[27] -1	0	0x0000e480 - 0x0000e49f (0x20) IX[B]
    	[28] -1	0	0x0000e800 - 0x0000e81f (0x20) IX[B]
    	[29] -1	0	0x0000e880 - 0x0000e89f (0x20) IX[B]
    	[30] -1	0	0x0000ec00 - 0x0000ec1f (0x20) IX[B]
    	[31] -1	0	0x0000b000 - 0x0000b0ff (0x100) IX[B](B)
    	[32] 0	0	0x000003b0 - 0x000003bb (0xc) IS[B]
    	[33] 0	0	0x000003c0 - 0x000003df (0x20) IS[B]
    (II) Setting vga for screen 0.
    (II) fglrx(0): === [atiddxPreInit] === begin
    (II) Loading sub module "vgahw"
    (II) LoadModule: "vgahw"
    (II) Loading /usr/lib64/xorg/modules//libvgahw.so
    (II) Module vgahw: vendor="X.Org Foundation"
    	compiled for 1.3.0, module version = 0.1.0
    (II) fglrx(0): PCI bus 1 card 0 func 0
    (**) fglrx(0): Depth 24, (--) framebuffer bpp 32
    (II) fglrx(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
    (==) fglrx(0): Default visual is TrueColor
    (**) fglrx(0): Option "DPMS" "true"
    (II) fglrx(0): Loading PCS database from /etc/ati/amdpcsdb
    (==) fglrx(0): RGB weight 888
    (II) fglrx(0): Using 8 bits per RGB (8 bit DAC)
    (==) fglrx(0): Gamma Correction for I is 0x06419064
    (==) fglrx(0): Gamma Correction for II is 0x06419064
    (==) fglrx(0): Buffer Tiling is ON
    (--) fglrx(0): Chipset: "ATI Mobility Radeon X1700" (Chipset = 0x71d5)
    (--) fglrx(0): (PciSubVendor = 0x1043, PciSubDevice = 0x1242)
    (--) fglrx(0): board vendor info: third party graphics adapter - NOT original ATI
    (--) fglrx(0): Linear framebuffer (phys) at 0xc0000000
    (--) fglrx(0): MMIO registers at 0xfdff0000
    (==) fglrx(0): ROM-BIOS at 0x000c0000
    (II) fglrx(0): Primary V_BIOS segment is: 0xc000
    (II) Loading sub module "vbe"
    (II) LoadModule: "vbe"
    (II) Loading /usr/lib64/xorg/modules//libvbe.so
    (II) Module vbe: vendor="X.Org Foundation"
    	compiled for 1.3.0, module version = 1.1.0
  6. Woodstock
    10 Sep 2006
    and some more of that log
    Code:
    (II) fglrx(0): VESA BIOS detected
    (II) fglrx(0): VESA VBE Version 3.0
    (II) fglrx(0): VESA VBE Total Mem: 16384 kB
    (II) fglrx(0): VESA VBE OEM: ATI ATOMBIOS
    (II) fglrx(0): VESA VBE OEM Software Rev: 9.12
    (II) fglrx(0): VESA VBE OEM Vendor: (C) 1988-2005, ATI Technologies Inc.
    (II) fglrx(0): VESA VBE OEM Product: M66P
    (II) fglrx(0): VESA VBE OEM Product Rev: 01.00
    (II) fglrx(0): ATI Video BIOS revision 9 or later detected
    drmOpenDevice: node name is /dev/dri/card0
    drmOpenDevice: open result is 6, (OK)
    drmGetBusid returned ''
    (II) Loading sub module "fglrxdrm"
    (II) LoadModule: "fglrxdrm"
    (II) Loading /usr/lib64/xorg/modules/linux//libfglrxdrm.so
    (II) Module fglrxdrm: vendor="FireGL - ATI Technologies Inc."
    (II) fglrx(0): Using adapter: 1:0.0.
    (--) fglrx(0): VideoRAM: 262144 kByte, Type: DDR2
    (II) fglrx(0): PCIE card detected
    (WW) fglrx(0): board is an unknown third party board, chipset is supported
    (II) Loading sub module "ddc"
    (II) LoadModule: "ddc"(II) Module already built-in
    (II) fglrx(0): Connected Display1: LCD on internal LVDS [lvds]
    (II) fglrx(0): Display1 EDID data ---------------------------
    (II) fglrx(0): Manufacturer: LPL  Model: c100  Serial#: 0
    (II) fglrx(0): Year: 2006  Week: 0
    (II) fglrx(0): EDID Version: 1.3
    (II) fglrx(0): Digital Display Input
    (II) fglrx(0): Max H-Image Size [cm]: horiz.: 33  vert.: 21
    (II) fglrx(0): Gamma: 2.20
    (II) fglrx(0): No DPMS capabilities specified; RGB/Color Display
    (II) fglrx(0): First detailed timing is preferred mode
    (II) fglrx(0): redX: 0.600 redY: 0.351   greenX: 0.324 greenY: 0.554
    (II) fglrx(0): blueX: 0.153 blueY: 0.140   whiteX: 0.312 whiteY: 0.328
    (II) fglrx(0): Manufacturer's mask: 0
    (II) fglrx(0): Supported additional Video Mode:
    (II) fglrx(0): clock: 68.9 MHz   Image Size:  331 x 207 mm
    (II) fglrx(0): h_active: 1280  h_sync: 1304  h_sync_end 1336 h_blank_end 1408 h_border: 0
    (II) fglrx(0): v_active: 800  v_sync: 804  v_sync_end 808 v_blanking: 816 v_border: 0
    (II) fglrx(0):  LGPhilipsLCD
    (II) fglrx(0):  LP154W01-TLD2
    (II) fglrx(0): EDID (in hex):
    (II) fglrx(0): 	00ffffffffffff00320c00c100000000
    (II) fglrx(0): 	00100103802115780ab3709959538d27
    (II) fglrx(0): 	23505400000001010101010101010101
    (II) fglrx(0): 	010101010101ea1a0080502010301820
    (II) fglrx(0): 	44004bcf100000190000000000000000
    (II) fglrx(0): 	00000000000000000000000000fe004c
    (II) fglrx(0): 	475068696c6970734c43440a000000fe
    (II) fglrx(0): 	004c503135345730312d544c4432005f
    (II) fglrx(0): End of Display1 EDID data --------------------
    (WW) fglrx(0): Only one display is connnected,so single mode is enabled
    (II) fglrx(0): Primary Controller - LCD on internal LVDS
    (II) fglrx(0): Internal Desktop Setting: 0x00000001
    (II) fglrx(0): POWERplay version 3.  5 power states available:
    (II) fglrx(0):   1. 459/396MHz @ 60Hz [overclocked, enable load balancing]
    (II) fglrx(0):   2. 128/135MHz @ 60Hz [low voltage, enable sleep]
    (II) fglrx(0):   3. 209/135MHz @ 60Hz [low voltage, enable sleep]
    (II) fglrx(0):   4. 324/135MHz @ 60Hz [low voltage, enable sleep]
    (II) fglrx(0):   5. 392/252MHz @ 60Hz [enable sleep]
    (==) fglrx(0): Qbs is not supported in this release. Disabled.
    (==) fglrx(0): FAST_SWAP disabled
    (==) fglrx(0):  PseudoColor visuals disabled
    (==) fglrx(0): Using gamma correction (1.0, 1.0, 1.0)
    (==) fglrx(0): Center Mode is disabled
    (==) fglrx(0): TMDS coherent mode is enabled
    (II) fglrx(0): Total of 10 modes found for primary display.
    (--) fglrx(0): Virtual size is 1280x800 (pitch 0)
    (**) fglrx(0): *Mode "1280x800": 68.9 MHz (scaled from 0.0 MHz), 48.9 kHz, 60.0 Hz
    (II) fglrx(0): Modeline "1280x800"   68.90  1280 1304 1336 1408  800 804 808 816 +hsync +vsync
    (**) fglrx(0): *Mode "1280x768": 68.9 MHz (scaled from 0.0 MHz), 48.9 kHz, 60.0 Hz
    (II) fglrx(0): Modeline "1280x768"   68.90  1280 1304 1336 1408  768 804 808 816 +hsync +vsync
    (**) fglrx(0): *Mode "1024x768": 68.9 MHz (scaled from 0.0 MHz), 48.9 kHz, 60.0 Hz
    (II) fglrx(0): Modeline "1024x768"   68.90  1024 1304 1336 1408  768 804 808 816 +hsync +vsync
    (**) fglrx(0): *Mode "800x600": 68.9 MHz (scaled from 0.0 MHz), 48.9 kHz, 60.0 Hz
    (II) fglrx(0): Modeline "800x600"   68.90  800 1304 1336 1408  600 804 808 816 +hsync +vsync
    (**) fglrx(0): *Mode "640x480": 68.9 MHz (scaled from 0.0 MHz), 48.9 kHz, 60.0 Hz
    (II) fglrx(0): Modeline "640x480"   68.90  640 1304 1336 1408  480 804 808 816 +hsync +vsync
    (**) fglrx(0):  Default mode "640x400": 68.9 MHz (scaled from 0.0 MHz), 48.9 kHz, 60.0 Hz
    (II) fglrx(0): Modeline "640x400"   68.90  640 1304 1336 1408  400 804 808 816 +hsync +vsync
    (**) fglrx(0):  Default mode "512x384": 68.9 MHz (scaled from 0.0 MHz), 48.9 kHz, 60.0 Hz
    (II) fglrx(0): Modeline "512x384"   68.90  512 1304 1336 1408  384 804 808 816 +hsync +vsync
    (**) fglrx(0):  Default mode "400x300": 68.9 MHz (scaled from 0.0 MHz), 48.9 kHz, 60.0 Hz
    (II) fglrx(0): Modeline "400x300"   68.90  400 1304 1336 1408  300 804 808 816 +hsync +vsync
    (**) fglrx(0):  Default mode "320x240": 68.9 MHz (scaled from 0.0 MHz), 48.9 kHz, 60.0 Hz
    (II) fglrx(0): Modeline "320x240"   68.90  320 1304 1336 1408  240 804 808 816 +hsync +vsync
    (**) fglrx(0):  Default mode "320x200": 68.9 MHz (scaled from 0.0 MHz), 48.9 kHz, 60.0 Hz
    (II) fglrx(0): Modeline "320x200"   68.90  320 1304 1336 1408  200 804 808 816 +hsync +vsync
    (--) fglrx(0): Display dimensions: (330, 210) mm
    (--) fglrx(0): DPI set to (98, 96)
    (--) fglrx(0): Virtual size is 1280x800 (pitch 1280)
    (II) Loading sub module "fb"
    (II) LoadModule: "fb"
    (II) Loading /usr/lib64/xorg/modules//libfb.so
    (II) Module fb: vendor="X.Org Foundation"
    	ABI class: X.Org ANSI C Emulation, version 0.3
    (II) Loading sub module "ramdac"
    (II) LoadModule: "ramdac"(II) Module already built-in
    (==) fglrx(0): NoAccel = NO
    (II) Loading sub module "xaa"
    (II) LoadModule: "xaa"
    (II) Loading /usr/lib64/xorg/modules//libxaa.so
    (II) Module xaa: vendor="X.Org Foundation"
    	compiled for 1.3.0, module version = 1.2.0
    (==) fglrx(0): NoDRI = NO
    (II) Reloading /usr/lib64/xorg/modules/linux//libfglrxdrm.so
    (II) fglrx(0): Depth moves disabled by default
    (==) fglrx(0): Capabilities: 0x00000000
    (==) fglrx(0): CapabilitiesEx: 0x00000000
    (==) fglrx(0): cpuFlags: 0x8000001d
    (==) fglrx(0): OpenGL ClientDriverName: "fglrx_dri.so"
    (**) fglrx(0): ATI GART size: 256 MB
    (II) fglrx(0): [pcie] 258048 kB allocated
    (II) fglrx(0): [drm] DRM buffer queue setup: nbufs = 100 bufsize = 65536
    (==) fglrx(0): UseFastTLS=0
    (==) fglrx(0): BlockSignalsOnLock=1
    (--) Depth 24 pixmap format is 32 bpp
    (II) do I need RAC?  No, I don't.
    (II) resource ranges after preInit:
    	[0] 0	0	0xfdff0000 - 0xfdffffff (0x10000) MX[B]
    	[1] 0	0	0xc0000000 - 0xcfffffff (0x10000000) MX[B]
    	[2] -1	0	0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
    	[3] -1	0	0x000f0000 - 0x000fffff (0x10000) MX[B]
    	[4] -1	0	0x000c0000 - 0x000effff (0x30000) MX[B]
    	[5] -1	0	0x00000000 - 0x0009ffff (0xa0000) MX[B]
    	[6] -1	0	0xfeafec00 - 0xfeafecff (0x100) MX[B]
    	[7] -1	0	0xfeaff000 - 0xfeaff0ff (0x100) MX[B]
    	[8] -1	0	0xfeaff400 - 0xfeaff4ff (0x100) MX[B]
    	[9] -1	0	0xfeaff800 - 0xfeafffff (0x800) MX[B]
    	[10] -1	0	0xfe1ff000 - 0xfe1fffff (0x1000) MX[B]
    	[11] -1	0	0xfe0ff000 - 0xfe0fffff (0x1000) MX[B]
    	[12] -1	0	0xfebfbc00 - 0xfebfbfff (0x400) MX[B]
    	[13] -1	0	0xfebfc000 - 0xfebfffff (0x4000) MX[B]
    	[14] -1	0	0xfdfc0000 - 0xfdfdffff (0x20000) MX[B](B)
    	[15] -1	0	0xfdff0000 - 0xfdffffff (0x10000) MX[B](B)
    	[16] -1	0	0xc0000000 - 0xcfffffff (0x10000000) MX[B](B)
    	[17] 0	0	0x000a0000 - 0x000affff (0x10000) MS[B](OprU)
    	[18] 0	0	0x000b0000 - 0x000b7fff (0x8000) MS[B](OprU)
    	[19] 0	0	0x000b8000 - 0x000bffff (0x8000) MS[B](OprU)
    	[20] 0	0	0x0000b000 - 0x0000b0ff (0x100) IX[B]
    	[21] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[B]
    	[22] -1	0	0x00000000 - 0x000000ff (0x100) IX[B]
    	[23] -1	0	0x0000c800 - 0x0000c8ff (0x100) IX[B]
    	[24] -1	0	0x00000400 - 0x0000041f (0x20) IX[B]
    	[25] -1	0	0x0000ffa0 - 0x0000ffaf (0x10) IX[B]
    	[26] -1	0	0x000001f0 - 0x000001f0 (0x1) IX[B]
    	[27] -1	0	0x000001f0 - 0x000001f7 (0x8) IX[B]
    	[28] -1	0	0x000001f0 - 0x000001f0 (0x1) IX[B]
    	[29] -1	0	0x000001f0 - 0x000001f7 (0x8) IX[B]
    	[30] -1	0	0x0000e480 - 0x0000e49f (0x20) IX[B]
    	[31] -1	0	0x0000e800 - 0x0000e81f (0x20) IX[B]
    	[32] -1	0	0x0000e880 - 0x0000e89f (0x20) IX[B]
    	[33] -1	0	0x0000ec00 - 0x0000ec1f (0x20) IX[B]
    	[34] -1	0	0x0000b000 - 0x0000b0ff (0x100) IX[B](B)
    	[35] 0	0	0x000003b0 - 0x000003bb (0xc) IS[B](OprU)
    	[36] 0	0	0x000003c0 - 0x000003df (0x20) IS[B](OprU)
    (II) fglrx(0): driver needs X.org 7.1.x.y with x.y >= 0.0
    (II) fglrx(0): detected X.org 7.1.0.0
    (II) Loading extension ATIFGLRXDRI
    (II) fglrx(0): doing DRIScreenInit
    drmOpenByBusid: Searching for BusID PCI:1:0:0
    drmOpenByBusid: drmOpenMinor returns 6
    drmOpenByBusid: drmGetBusid reports
    drmOpenDevice: node name is /dev/dri/card1
    drmOpenDevice: open result is -1, (No such device)
    drmOpenDevice: Open failed
    drmOpenByBusid: drmOpenMinor returns -19
    drmOpenDevice: node name is /dev/dri/card2
    drmOpenDevice: node name is /dev/dri/card3
    drmOpenDevice: node name is /dev/dri/card4
    drmOpenDevice: node name is /dev/dri/card5
    drmOpenDevice: node name is /dev/dri/card6
    drmOpenDevice: node name is /dev/dri/card7
    drmOpenDevice: node name is /dev/dri/card8
    drmOpenDevice: node name is /dev/dri/card9
    drmOpenDevice: node name is /dev/dri/card10
    drmOpenDevice: node name is /dev/dri/card11
    drmOpenDevice: node name is /dev/dri/card12
    drmOpenDevice: node name is /dev/dri/card13
    drmOpenDevice: node name is /dev/dri/card14
    (II) fglrx(0): [drm] DRM interface version 1.0
    (II) fglrx(0): [drm] created "fglrx" driver at busid "PCI:1:0:0"
    (II) fglrx(0): [drm] added 8192 byte SAREA at 0x47000
    (II) fglrx(0): [drm] mapped SAREA 0x47000 to 0x2b4f24881000
    (II) fglrx(0): [drm] framebuffer handle = 0x48000
    (II) fglrx(0): [drm] added 1 reserved context for kernel
    (II) fglrx(0): DRIScreenInit done
    (II) fglrx(0): Kernel Module Version Information:
    (II) fglrx(0):     Name: fglrx
    (II) fglrx(0):     Version: 8.47.3
    (II) fglrx(0):     Date: Mar 29 2008
    (II) fglrx(0):     Desc: ATI FireGL DRM kernel module
    (II) fglrx(0): Kernel Module version matches driver.
    (II) fglrx(0): Kernel Module Build Time Information:
    (II) fglrx(0):     Build-Kernel UTS_RELEASE:        2.6.24-gentoo-r8
    (II) fglrx(0):     Build-Kernel MODVERSIONS:        no
    (II) fglrx(0):     Build-Kernel __SMP__:            yes
    (II) fglrx(0):     Build-Kernel PAGE_SIZE:          0x1000
    (II) fglrx(0): [drm] register handle = 0x00049000
    (II) fglrx(0): Interrupt handler installed at IRQ 16.
    (II) fglrx(0): Exposed events to the /proc interface
    (II) fglrx(0): DRI initialization successfull!
    (II) fglrx(0): FBADPhys: 0xc0000000 FBMappedSize: 0x01004000
    (II) fglrx(0): FBMM initialized for area (0,0)-(1280,3280)
    (II) fglrx(0): FBMM auto alloc for area (0,0)-(1280,800) (front color buffer - assumption)
    (II) fglrx(0): Largest offscreen area available: 1280 x 2480
    (==) fglrx(0): Backing store disabled
    (II) Loading extension FGLRXEXTENSION
    (II) Loading extension ATITVOUT
    (**) fglrx(0): DPMS enabled
    (**) fglrx(0): Textured Video is enabled.
    (II) LoadModule: "glesx"
    (II) Loading /usr/lib64/xorg/modules//glesx.so
    (II) Module glesx: vendor="X.Org Foundation"
    	compiled for 7.1.0, module version = 1.0.0
    (II) Loading extension GLESX
    (II) fglrx(0): GLESX enableFlags = 16
    (II) fglrx(0): GLESX is enabled
    (II) fglrx(0): Using XFree86 Acceleration Architecture (XAA)
    	Screen to screen bit blits
    	Solid filled rectangles
    	8x8 mono pattern filled rectangles
    	Solid Lines
    	Dashed Lines
    	Offscreen Pixmaps
    	Setting up tile and stipple cache:
    		32 128x128 slots
    		19 256x256 slots
    		5 512x512 slots
    (II) fglrx(0): Acceleration enabled
    (WW) fglrx(0): Option "VendorName" is not used
    (WW) fglrx(0): Option "ModelName" is not used
    (II) fglrx(0): X context handle = 0x1
    (II) fglrx(0): [DRI] installation complete
    (II) fglrx(0): Direct rendering enabled
    [atiddx] ASYNCIO init succeed!
    Receive enable interrupt ret message
    ...irqEnableMask: 10000000
    ...dwIRQEnableId: 00000008
    (==) fglrx(0): Silken mouse enabled
    (==) fglrx(0): Using hardware cursor
    (==) RandR enabled
    (II) Initializing built-in extension MIT-SHM
    (II) Initializing built-in extension XInputExtension
    (II) Initializing built-in extension XTEST
    (II) Initializing built-in extension XKEYBOARD
    (II) Initializing built-in extension XC-APPGROUP
    (II) Initializing built-in extension XAccessControlExtension
    (II) Initializing built-in extension SECURITY
    (II) Initializing built-in extension XINERAMA
    (II) Initializing built-in extension XFIXES
    (II) Initializing built-in extension XFree86-Bigfont
    (II) Initializing built-in extension RENDER
    (II) Initializing built-in extension RANDR
    (II) Initializing built-in extension COMPOSITE
    (II) Initializing built-in extension DAMAGE
    (II) Initializing built-in extension XEVIE
    drmOpenDevice: open result is 7, (OK)
    drmOpenByBusid: drmOpenMinor returns 7
    drmOpenByBusid: drmGetBusid reports PCI:1:0:0
  7. Woodstock
    10 Sep 2006
    and the rest
    Code:
    (WW) AIGLX: 3D driver claims to not support visual 0x23
    (WW) AIGLX: 3D driver claims to not support visual 0x24
    (WW) AIGLX: 3D driver claims to not support visual 0x25
    (WW) AIGLX: 3D driver claims to not support visual 0x26
    (WW) AIGLX: 3D driver claims to not support visual 0x27
    (WW) AIGLX: 3D driver claims to not support visual 0x28
    (WW) AIGLX: 3D driver claims to not support visual 0x29
    (WW) AIGLX: 3D driver claims to not support visual 0x2a
    (WW) AIGLX: 3D driver claims to not support visual 0x2b
    (WW) AIGLX: 3D driver claims to not support visual 0x2c
    (WW) AIGLX: 3D driver claims to not support visual 0x2d
    (WW) AIGLX: 3D driver claims to not support visual 0x2e
    (WW) AIGLX: 3D driver claims to not support visual 0x2f
    (WW) AIGLX: 3D driver claims to not support visual 0x30
    (WW) AIGLX: 3D driver claims to not support visual 0x31
    (WW) AIGLX: 3D driver claims to not support visual 0x32
    (WW) AIGLX: 3D driver claims to not support visual 0x33
    (WW) AIGLX: 3D driver claims to not support visual 0x34
    (WW) AIGLX: 3D driver claims to not support visual 0x35
    (WW) AIGLX: 3D driver claims to not support visual 0x36
    (WW) AIGLX: 3D driver claims to not support visual 0x37
    (WW) AIGLX: 3D driver claims to not support visual 0x38
    (WW) AIGLX: 3D driver claims to not support visual 0x39
    (WW) AIGLX: 3D driver claims to not support visual 0x3a
    (WW) AIGLX: 3D driver claims to not support visual 0x3b
    (WW) AIGLX: 3D driver claims to not support visual 0x3c
    (WW) AIGLX: 3D driver claims to not support visual 0x3d
    (WW) AIGLX: 3D driver claims to not support visual 0x3e
    (WW) AIGLX: 3D driver claims to not support visual 0x3f
    (WW) AIGLX: 3D driver claims to not support visual 0x40
    (WW) AIGLX: 3D driver claims to not support visual 0x41
    (WW) AIGLX: 3D driver claims to not support visual 0x42
    (WW) AIGLX: 3D driver claims to not support visual 0x43
    (WW) AIGLX: 3D driver claims to not support visual 0x44
    (WW) AIGLX: 3D driver claims to not support visual 0x45
    (WW) AIGLX: 3D driver claims to not support visual 0x46
    (WW) AIGLX: 3D driver claims to not support visual 0x47
    (WW) AIGLX: 3D driver claims to not support visual 0x48
    (WW) AIGLX: 3D driver claims to not support visual 0x49
    (WW) AIGLX: 3D driver claims to not support visual 0x4a
    (WW) AIGLX: 3D driver claims to not support visual 0x4b
    (WW) AIGLX: 3D driver claims to not support visual 0x4c
    (WW) AIGLX: 3D driver claims to not support visual 0x4d
    (WW) AIGLX: 3D driver claims to not support visual 0x4e
    (WW) AIGLX: 3D driver claims to not support visual 0x4f
    (WW) AIGLX: 3D driver claims to not support visual 0x50
    (WW) AIGLX: 3D driver claims to not support visual 0x51
    (WW) AIGLX: 3D driver claims to not support visual 0x52
    (WW) AIGLX: 3D driver claims to not support visual 0x53
    (WW) AIGLX: 3D driver claims to not support visual 0x54
    (WW) AIGLX: 3D driver claims to not support visual 0x55
    (WW) AIGLX: 3D driver claims to not support visual 0x56
    (WW) AIGLX: 3D driver claims to not support visual 0x57
    (WW) AIGLX: 3D driver claims to not support visual 0x58
    (WW) AIGLX: 3D driver claims to not support visual 0x59
    (WW) AIGLX: 3D driver claims to not support visual 0x5a
    (WW) AIGLX: 3D driver claims to not support visual 0x5b
    (WW) AIGLX: 3D driver claims to not support visual 0x5c
    (WW) AIGLX: 3D driver claims to not support visual 0x5d
    (WW) AIGLX: 3D driver claims to not support visual 0x5e
    (WW) AIGLX: 3D driver claims to not support visual 0x5f
    (WW) AIGLX: 3D driver claims to not support visual 0x60
    (WW) AIGLX: 3D driver claims to not support visual 0x61
    (WW) AIGLX: 3D driver claims to not support visual 0x62
    (WW) AIGLX: 3D driver claims to not support visual 0x63
    (WW) AIGLX: 3D driver claims to not support visual 0x64
    (WW) AIGLX: 3D driver claims to not support visual 0x65
    (WW) AIGLX: 3D driver claims to not support visual 0x66
    (WW) AIGLX: 3D driver claims to not support visual 0x67
    (WW) AIGLX: 3D driver claims to not support visual 0x68
    (WW) AIGLX: 3D driver claims to not support visual 0x69
    (WW) AIGLX: 3D driver claims to not support visual 0x6a
    (WW) AIGLX: 3D driver claims to not support visual 0x6b
    (WW) AIGLX: 3D driver claims to not support visual 0x6c
    (WW) AIGLX: 3D driver claims to not support visual 0x6d
    (WW) AIGLX: 3D driver claims to not support visual 0x6e
    (WW) AIGLX: 3D driver claims to not support visual 0x6f
    (WW) AIGLX: 3D driver claims to not support visual 0x70
    (WW) AIGLX: 3D driver claims to not support visual 0x71
    (WW) AIGLX: 3D driver claims to not support visual 0x72
    (II) AIGLX: Loaded and initialized /usr/lib64/dri/fglrx_dri.so
    (II) GLX: Initialized DRI GL provider for screen 0
    (EE) No Input driver matching `mouse'
    (EE) No Input driver matching `kbd'
    (WW) No core pointer registered
    No core keyboard
    Fatal server error:
    failed to initialize core devices
    (II) AIGLX: Suspending AIGLX clients for VT switch
  8. Fophillips
    9 Oct 2006
    Basically, you have no mouse or keyboard drivers. You need to install x11-drivers/xf86-input-mouse and x11-drivers/xf86-input-keyboard
  9. Woodstock
    10 Sep 2006
    okay ill give that a go soon, im pretty sure i emerged the synatpic driver thou
    edit: chears im now looking at the ugly TWM even have dual monitor (res needs fixing thou) , whatevers stopping links to compile is also affecting fluxbox :(
    edit: if a masked package is unmasked, how would one go about remasking it i tried deleting from package.unmask and adding to package.mask but neither worked
  10. DougEdey
    5 Jul 2005
    Btw, when posting logs, use a file host, if you want to email them to me I can host
  11. Woodstock
    10 Sep 2006
    i did think hosting them elsewhere would have been better but didnt have any availble at the time, ill keep that in mind if i have to post any others
  12. Fophillips
    9 Oct 2006
    To use the synaptics driver you have to specify synaptics in xorg.conf. Take a look at http://gentoo-wiki.com/HARDWARE_Synaptics_Touchpad
    I don’t use emerge, but I’m pretty sure removing from package.unmask should do it, you sure it’s not keyworded instead? Looks for ACCEPT_KEYWORDS in make.conf
  13. Glider
    Glider /dev/null
    2 Aug 2005
    Remove it from package.unmask and reupdate the system (emerge -avuDNt world)
  14. Woodstock
    10 Sep 2006
    cheers glider that appears to have fixed the problem (once i hardmasked bash it was being blocked by portage with a solution i come up with for a different problem which turned out to make more problems and didnt solve the orginal
    @fophillips
    when you say you dont use emerge are you saying that you use that plaudis(?) that ive heard about? emerge deffinatly appears to be considerably better then apt and what ive seen of yum
    i think ive solved the compiler problems and believe i need a good slapping about it, slight typo in make.conf "CXXFLAGS={CHOST}" instead of "CXXFLAGS=${CHOST}, and if i recall $is variable or use this varible
  15. Glider
    Glider /dev/null
    2 Aug 2005
    Portage is miles better then apt, the intelligence it has is just unique ;)
  16. Woodstock
    10 Sep 2006
    both have there places thou
  17. Fophillips
    9 Oct 2006
    Yeah I use paludis, far superior in many ways :p
  18. Glider
    Glider /dev/null
    2 Aug 2005
    But flawed in some others... It has potential, but I'm going to stick with the 'standard' stuff :D
  19. Woodstock
    10 Sep 2006
    mostly up and running, i just cant connect to the proxy server (using links) and im going around in circles trying to get info on proxies (not the server part theres a lot of stuff on that), but is there a package that will log me into the proxy and allow all my net-apps to run webbrowser,irc,amsn and email being the main ones, portage would be nice as well
  20. Glider
    Glider /dev/null
    2 Aug 2005
    Code:
    export http_proxy="<proxy>:<port>"
    export ftp_proxy="<proxy>:<port>"
