Acer acer travelmate 2310 laptop cd rom drive failure
Discussion in 'Tech Support' started by The cheapskate, 14 Jan 2007.
  1. The cheapskate
    The cheapskate One custom title before Matty
    27 Oct 2004
    Hey guys,
    as title really, the thing is out of warrenty, im just wondering what best to do?
    Its a mates, and she needs it for her work, SO sending it back and paying for repairs is only realy an option if acer are quick in the turn around.
    failing that, any idea were I can pick one up, online? and how hard it will be to fit?
    cheers gentlemen. :hip:
    any one with a decent answer can get drunk on as many e-beers they like :thumb:
  2. Krikkit
    21 Jan 2003
    Well one option is to get her to buy an external drive - that's a quick fix. If you pull the CD-drive, you can probably get a new one on eBay, but you never know. :thumb:
  3. Pointy Burdz
    Pointy Burdz What's a Dremel?
    24 Jul 2004
    one of my work colleagues uses an Acer Ferrari laptop which has a slot loading optical drive, if yours is the same you can get a Liteon SLW-831S from Dabs for around 40 quid, I got one for my precision laptop some months ago but took it out again as the powered load/eject was too noisy for me :duh: , swapping out was a 3 min op and OS recognised the hardware upon reboot.
    IIRC the Acer has a bezel which is painted red on the Ferrari model, this is just a cosmetic piece and the drive you buy I reckon will sit behind it no problem.
  4. M4RTIN
    M4RTIN What's a Dremel?
    11 Sep 2006
    whereabout can you actually get laptop drives from? ive looked at all the usual online stores and they dont offer slimline drives. im after one for a compag laptop which im pretty damn sure just uses a standard type slim drive
