Notebooks Acer Aspire 5741G 15.6 NB with Intel Core i3 Review
Discussion in 'Hardware' started by windwithme, 3 Nov 2010.
  1. windwithme
    windwithme Minimodder
    14 Jul 2009
    Acer Aspire 5741G
    Lower right side is monitor lock and SD memory card slot
    SD / MMC / xD / MS / MS Pro
    15.6” matte monitor, the resolution is 1366X768. The open degree is 140~150.
    Right Side
    2 X USB 2.0\8X Super Multi DL DVD\anti-thief lock
    Left side
    Power in, thermal holes, D-SUB, RJ45 LAN, HDMI, USB, Mic in, Line out
    6 Cell battery => 2524g
  2. windwithme
    14 Jul 2009
    Acer Aspire 5741G uses Intel latest Calpella structure.
    CPU is Intel Core i3-330M. The clock is 133 X 16 => 2.13GHz, L3 3MB, dual core and supports HT technology.
    The chipset is HM55. Comparing to GM45, I believe the performance will be much better.
    Performance test
    OS is Windows7 Ultimate 64Bit
    Hardware info in Device Manager
    Windows7 system performance
    CPU performance test
    Super PI 32M => 33m 49.943s
    CPUMARK99 => 327
    Nuclearus Multi Core => 8243
    Fritz Chess Benchmark => 8.06/3869
    CrystalMark 2004R3 => 128764
    CINEBENCH 11.5
    OpenGL 12.16fps
    CPU (Single Core) 0.69pts
    MP Ratio 2.54x
    PCMark Vantage => 8607
    Using high performance MLC SSD-CORSAIR F60 to test
    Size is 2.5” and ID is F60. The highest performance is 285/275 MB/s.
    Random 4K writing performance can reach 50000 IOPS which improve the 4K writing issue in past SSD.
  3. windwithme
    14 Jul 2009
    ATTO DISK Benchmark over 128k benchmark result is max read 283.7 Mb/s and write 261.8 MB/s
    EVEREST File Benchmark over 1024k benchmark result also above 250 MB/s.
    CrystalDiskMark 4K QD32 Read - 105.3 MB/s Write - 62.26 MB/s
    AS SSD Benchmark
    Seq Read - 192.96 MB/s Write - 52.90 MB/s
    4K-64Thrd Read - 105.67 MB/s Write - 47.51 MB/s
    3D - ATI Mobility Radeon HD 5650, 1024MB GDDR3
    3DMARK2006 - 7235
    DEVIL MAY CRY4
    DX10 1280 X 720 => 69.13/64.87/93.97/51.07 fps
    StreetFighter IV Benchmark
    1280 X 720 => 85.50FPS
    Biohazard5 Benchmark
    1280 X 720 => 19.5fps
    DRAM performance
    DDR3 1064.2 CL7 7-7-20 1T
    Sandra Memory Bandwidth - 7354MB/s
    EVEREST Memory Read - 9063MB/s
    CPU Temperature
    Standby - 39~45℃
    CPU full speed - 74~80℃
  4. windwithme
    14 Jul 2009
    Video
    1280 X 720 => CPU 23%
    1440 X 1080 => CPU 22%
    Battery Duration
    6Cell battery, Battery Eater Pro (turn off wifi and bluetooth)
    Full Speed - 1:21:19
    Standby - 3:47:28
    Acer Aspire 5741G
    Performance ★★★★★★★★☆☆
    Components ★★★★★★★☆☆☆
    Specification ★★★★★★★★☆☆
    Outlook ★★★★★★★★★☆
    C/P Value ★★★★★★★★★☆
    (If Using HDD 500GB & ATI HD 5450)
    Finally, I attach the Spyder2 color correction file for all 5741Gusers.
    Thanks for reading this Acer Aspire 5741G review.
    windwithme Acer Aspire 5741G
    This review also post in my blog WIND'S 3C
    Welcome 3C lovers to visit and advise.
