Notebooks Acer D250 Fault?
Discussion in 'Tech Support' started by Gunter, 13 Apr 2010.
  1. Gunter
    Gunter What's a Dremel?
    14 Feb 2009
    Well guys, I need help with this aspire one netbook, I don´t know exactly what´s happening, but shortly is this, my friend told me that it was working and suddently it crashed, ok, then he tried to boot but the machine only turn the cooler on, the power and battery light´s show up, like 4 seconds the cooler stops, but the machine keep getting warm, so I tried this things:
    1 Remove and Clean memory. (nothing)
    2 Change memory. (nothing)
    3 Change HD. (nothing)
    4 The Fn+Esc + bios in a pendrive, trying to acess acer crisis flash (nothing)
    Somebody has a clue?
  2. confusis
    confusis Kiwi-modder
    5 Jan 2006
    Do netbooks have a changeable cpu? Processor may have cooked itself at some point? Also is battery fully charged or charging properly?
  3. johnmalc
    johnmalc That shouldn't happen....
    7 Jul 2007
  4. Gunter
    14 Feb 2009
    Well about this question the cpu is weld to the mb, the baterry charges properly and it´s full.
    Yes I renamed to the acer file name in the .fd file, but nothing.
    Today I just give up and declare a dead mb. Thanks for the retrieving but there are some problems that we can solve buying an eee.
  5. XP1
    XP1 XP1
    25 Jun 2010
    I also tried this http://macles.blogspot.com/p/crisis.html, but it did not work.
    I then removed the RAM and cleaned the pins with an eraser.
    It works now!
    I think in order to use the BIOS recovery function, you need to have functional RAM. Double check your other hardware components if the BIOS recovery function does not work.
    My older post from another forum thread:
    Those instructions pertain mostly to the AOD110 and AOD150 models. Acer support says those instructions will not work on other models, such as the AOD250 in my case.
