Displays Acer X233Hbd 23" - Any downside?
Discussion in 'Hardware' started by shaleenh, 31 Jul 2009.
  1. shaleenh
    shaleenh What's a Dremel?
    31 Jul 2009
    Hi,
    I was thinking of buying the Acer X233Hbd 23". It appears to be a very nice monitor.
    http://www.overclockers.co.uk/showproduct.php?prodid=MO-043-AC&groupid=17&catid=1425&subcat=
    - Screen Size: 23" Widescreen
    - Resolution: 1920x1080
    - Contrast Ratio: 40000:1
    - Brightness: 300cd/m²
    - Response Time: 5ms
    - Viewing Angles (H/V): 170°/160°
    - Colours: 16.7 Million
    - Inputs: 1x Analogue & 1x DVI-D
    - VESA Compliant
    - Dimensions: 561.6mm x 393.3mm x 177.5mm
    - Weight: 4.8kg
    - Warranty: 3 Years
    For £139.99 inc VAT it seems to be significantly cheaper than other comparable monitors. Is there any major downside that I'm missing?
    From reviews, it seems that the stand is not very adjustable, but that is not a big deal for me.
    Thanks.
  2. NeedlesKane
    NeedlesKane You're a Dremel
    2 Aug 2008
    from looking at the specs it seems to be a decent monitor for the price. i suggest buying it!
  3. shaleenh
    31 Jul 2009
    Thanks for the confirmation. I was afraid I might be missing something, as it has been a long time since I set up my own system.
  4. Elton
    23 Jan 2009
    Aside from it being a TN panel and that it's ACER it's fine.
    I'd buy it if i was in a pinch though.
    But overall there isn't much to complain about, unless you're a long time IPS user.
  5. MaverickWill
    MaverickWill Dirty CPC Mackem
    26 Apr 2009
    Nothing wrong with it, except the retailer. Search the forums for "OcUK" and take a read.
  6. shaleenh
    31 Jul 2009
    What do you mean by IPS?
    EDIT: Figured it out. :)
    Thanks for the warning. Unfortunately, OcUK is the one of only to carry the DVI + VGA version of this monitor. The other alternative is Pixmania, which is significantly cheaper but they seem to have a worse reputation.
    http://www.pixmania.co.uk/uk/uk/315...?srcid=738&Partenaire=kelkoo_uk&CodePromo=oui
  7. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    A worse reputation than OCuk? Don't make me laugh! :hehe:
