Modding Acrylic Cased Goodness
Discussion in 'Modding' started by Judge, 12 Dec 2002.
  1. Judge
    Judge What's a Dremel?
    12 Dec 2002
    I'm looking for sheets of acrylic that i could use to make my case would this product be suitable - from http://www.technologysupplies.co.uk/ Order code 490-208
    I obviously want the case to be rigid but the plastic needs to be able to be molded round corners. Is this the kinda stuff i'm after??
    Matt
  2. Judge
    12 Dec 2002
    Ooops thats no good needs to be about this thickness yes/no?
    prod code: 490-335
  3. eddie_dane
    eddie_dane Used to mod pc's now I mod houses
    31 Jan 2002
    I couldn't find the 490-335 so not sure of it's thickness. the 490-208 is 5mm thick... that should be fine... almost 1.4" which is what Linear used on his outside walls on the invisible case.
    One bit of advice would be to opt for the cast stock instead of the extruded. Costs more but there is a reason for that. Just my $.02
