Electronics Actuated panels
Discussion in 'Modding' started by ninjaplease, 31 Mar 2012.
  1. ninjaplease
    ninjaplease I don't know what I'm doing
    11 Jan 2012
    Planning a scratch build to do over the summer and one of my friends mentioned actuated panels on some Alienware cases. How impossible would this be to do? My initial thoughts were to somehow install some RC servos, somehow controlled and powered by 3 pin fan connectors on my mobo...
    Would that work? I'm open to any ideas or suggestions you may have.
    Thanks :thumb:
  2. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    I'd use servos and an arduino. You'd be able to toggle the analog output on the arduino from off to on and that way control the servos. Though you would need some beefy servos if you want to move the side panels.
  3. mrMonkeyChunks
    mrMonkeyChunks EVGA Cheesecake
    4 Mar 2012
    It would be cool if you could wire a temperature sensor up to the arduino, have it activate the panels and maybe some fans when a certain temperature inside the case is reached.
    I'm not very clued up on arduino tech so whether that's actually possible is a different matter entirely.
  4. ninjaplease
    11 Jan 2012
    Liking it, two of my housemates are electrical engineers and one of them is working with arduino this year so I'll look into it.
  5. Tessimm
    Tessimm Banned
    31 Mar 2012
    Oh, that's Great SIR !!
  6. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    If you like the idea of manual control at all ( to set the angle etc of the panels or vents ), then a simple servo tester would give you a nice clean knob as the controller ( mounted in the front of the case or what-not )- since servos run from 4.8-6.0 generally, USB power would be perfect, or the 5.5v rail...
    Also, you may like these:
    http://store.firgelli.com/
    http://www.trossenrobotics.com/robot-parts.aspx
    EDIT: on reflection, I think a servo and push-rod linkages would be somewhat cheaper than the miniature actuators, cool as they are :lol:
    ninjaplease likes this.
  7. Device Unknown
    Device Unknown What's a Dremel?
    13 Jul 2011
    Arduino's are expensive to use for just something simple like that. Look into a Teensy www.pjrc.com
    14 bucks you get a well..teensy chip that can be used as a LCD driver, fan controller, Servo controller and hundreds of other things. Cheap enough to develop for a single use and forget it.
  8. ninjaplease
    11 Jan 2012
    My wallet prefers using servo testers (which I had no idea even existed) and some el cheapo servos and actuating arms. Would be cool to have an automatic system that worked on heat levels, but knowing me, chances are it'd go wrong.
    Before I buy anything though Imma look into the teensy board thing, although being in the UK I'll have to find an alternate supplier.
  9. geebles
    geebles Own's a Dremel
    6 Jun 2011
    If you have a friend who has an Arduino dev board, you can just buy the chip (I got one for £3 off ebay) and you can ask to borrow his dev board and swap out the chips, program yours and youre away! Chip can be removed and used as standalone :)
    I advise playing around/finding someone who knows about it to begin with, how much are these servo testers?
  10. ninjaplease
    11 Jan 2012
    Yeah I'll have words with him when I get back (couple weeks probs), it might be something I eventually upgrade to.
    Servo testers are £2-£3 on ebay and will be really easy to power from a molex plug. Next step I guess is to come up with a design for the panels themselves...
  11. SXRguyinMA
    SXRguyinMA What's a Dremel?
    28 Jun 2011
  12. Archer
    Archer Talga Vassternich - Deserve Victory
    10 Jan 2011
    Thats why you wire/code it in such a way that if anything goes wrong it defaults to fully open ;)
    I'll be doing this exact thing on my next build, varying the angle of the panels by water temp, as well as fan speed
  13. SXRguyinMA
    28 Jun 2011
    I've got the board layout and coding for the angle/temp part, wouldn't be hard to add in fan control. See my first link in my post above yours :)
  14. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    Which way would you panel be actuated ? Sliding ? Rotating ? What will the panel weight be ? Depending on that, you'll probably need an high torque servo.
    BTW, I like the idea. I'm working on an actuated LCD (in-dash + flip-up) for a media PC project. I'll follow this :)
  15. Archer
    10 Jan 2011
    Thanks. I've already got my code actually, and want to actually do the board layout myself as well since I enjoy it and havent done it in ages. If I get stuck I'll be sure to have a peak though :p
  16. ninjaplease
    11 Jan 2012
    I'm still working on the panel design, this is all giving me a lot of confidence though. Would any of you be interested in a little collaborative work?
  17. ninjaplease
    11 Jan 2012
    New post to make this thread look popular..
    The design I'm working on at the moment has two closable exhaust grilles (actuated by a sliding grill on the inside face) on the top of the case, with large fans underneath that operate when they open. It also has a row of hinged flaps on each side of the case, near the bottom, that act as inlets.
    The idea is that the inlets have a relatively small area, causing an increase in air velocity and a corresponding increase in cooling.
    What do y'all think? Sketches and CAD to follow.
  18. GuilleAcoustic
    26 Nov 2010
    I had thought of something similar for a tower design :
    The fans could be turned ON/OFF individually and automatically depending on the temperature. When a fan is activated, the "fins" in front of it are actuated so that the air flow can exists.
  19. ninjaplease
    11 Jan 2012
    Interesting, how far did you get with the planning? Or is it just a concept?
  20. mrMonkeyChunks
    4 Mar 2012
    Also is that column for mounting the fans or is it a absolutely massive radiator?
