Storage Adapters for a SSD to fit in a 5.25" slot
Discussion in 'Hardware' started by BorgmanJayce, 8 Oct 2009.
  1. BorgmanJayce
    BorgmanJayce What's a Dremel?
    8 Oct 2009
    Does anyone know if there are any adapters for SSD's that would allow it to fit into a 5.25" drive as I'm looking at using one of the 5.25" slots on a HTPC case for a SSD drive for Windows 7 to be installed on it plus various software with the other 5.25" slot being used for a BD-Drive and the 3.5" drive slots being used for SATA Drives.
  2. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    I don't think so. But you could buy a 2.5 to 3.5 adapter, and then mount that in a 3.5 to 5.25 adapter.
  3. BorgmanJayce
    8 Oct 2009
    I knew there were 2.5" to 3.5" inch adapters but I didn't think it was possible to fit it within a 3.5" to 5.25" adapter?
  4. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    I don't see why not. After all, the purpose of a 3.5 adapter is to be like a 3.5 drive. And since 5.25 adapters are designed to take 3.5 drives, it should be just fine.
  5. Krikkit
    21 Jan 2003
    Yep, and you don't need to worry about excess vibration because it's an SSD, so you can buy pretty much any adapters you like.
  6. simonw
    simonw What's a Dremel?
    24 Jun 2009
  7. BorgmanJayce
    8 Oct 2009
    It looks pretty cool [if you'll pardon the pun!] and definitely sounds like what I need! :)
  8. Nodule
    Nodule What's a Dremel?
    1 Aug 2009
    Crucial do a little kit for their drives which gives you a load of adapters for 3.5", 5.25", external and even a bag. One note though - the 5.25" adapter basically has the SSD stick out the front in a hot-swapabble way.
    simonw likes this.
  9. simonw
    24 Jun 2009
    Wow, that's really quite nice, considering you get an 2.5" external enclosure, plus an internal drive bay, all for £21.84.
