Other Addictive flash synthesizer
Discussion in 'General' started by glaeken, 29 Sep 2009.
  1. glaeken
    glaeken Freeeeeeeze! I'm a cawp!
    1 Jan 2005
    http://lab.andre-michelle.com/tonematrix
    Spent quite a bit playing around with this.
    Edit:
    BT: 106560,53384,108804,512,129028,68104,84240,112776,2624,129280,2688,35076,74370,17476,43560,70660
    65730,34088,84496,38056,67924,42152,78096,69282,36548,69928,38552,68692,38056,76368,33056,65730
    102402,106500,16584,42288,72274,71714,17492,74396,102694,84546,9252,22680,103504,47800,16678,90946
    74560,71040,67840,34432,16704,20640,39104,69920,74240,114952,17416,33792,67616,74816,41600,16640
    DarkLord7854 likes this.
  2. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    69506,34946,19134,36482,85762,33408,20286,98312,20232,32958,82688,32958,20266,20394,35498,68224
    16376,16388,34034,72842,74890,83098,83186,91138,95234,95474,95370,91274,79002,36082,16388,16376
  3. Jumeira_Johnny
    Jumeira_Johnny 16032 - High plains drifter
    13 Nov 2004
    my day is now listed as non productive
  4. VipersGratitude
    VipersGratitude Multimodder
    4 Mar 2008
  5. Krikkit
    21 Jan 2003
    Awesome. A flash Tenori-on, I wondered how long that would take. Shame you can't alter the pitch.
    65824,33168,20232,19464,34576,65824,69408,34832,20256,16672,18208,4224,0,1024,2432,1280
  6. 13eightyfour
    13eightyfour Formerly Titanium Angel
    9 Sep 2003
    Quite fun, great for messing about when bored :thumb:
    41414,50324,23124,10376,34076,17684,37792,76882,103968,91798,18832,33368,11680,29296,34952,79204
  7. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    Wow, no matter what you press in, it always sounds good, :D
  8. Cookie Monster
    Cookie Monster Multimodder
    27 Aug 2003
  9. acron^
    acron^ ePeen++;
    15 Oct 2001
    That's amaaaaaazing!
  10. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    160,160,0,160,0,320,160,0,40,0,0,0,2560,0,0,0
  11. flibblesan
    flibblesan Destroyer
    27 Jul 2005
    28830,3028,4760,0,12698,19264,12932,30,12692,19008,19008,0,31680,4224,27392,0
    then I apologise for this:
    15360,16896,16896,16896,16896,10236,34,46,34,10236,16896,16896,16896,16896,15360,0
  12. dragontail
    dragontail 5bet Bluffer
    9 Jun 2005
  13. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
  14. DarkLord7854
    DarkLord7854 What's a Dremel?
    22 Jun 2005
  15. Prestidigitweeze
    Prestidigitweeze "Oblivion ha-ha" to you, too.
    14 May 2008
    This one's an homage to Isan:
    16416,0,1024,1152,1088,0,4640,512,528,0,33040,264,260,2178,136,4
    This could be part of the jingle for an 80s Japanese pearl commercial:
    40960,81984,0,9232,4608,2312,0,43272,4612,576,2,21060,288,1152,0,10240
    Friends, our flash sequencer of the day is tuned to a pentatonic scale: the Ryo Onkai, in the above versions. However, the implied root I began with is not necessarily the lowest note available to the synth.
    Emphasizing said lowest note in octaves in the next sequence, I get a major second and a minor third, followed by two major seconds. Alternately, in the key of C Major, it would be G-A-C-D-E (or V-VI-I-II-III).
    This isn't my favorite mini-effort, but it highlights the scale and range of the synth from bottom to top:
    67648,67744,67904,68224,33872,37888,41984,37928,19104,18944,18944,17920,8456,4228,16912,33824
  16. 500mph
    22 Jun 2007
    I call this one Snow Falling Over A Mountain Onto a Peaceful Stream
    66082,99072,33156,33536,33280,33544,33152,32964,16768,17160,25088,8970,8576,8960,12810,4864
    It seems to miss a line.
  17. Furymouse
    Furymouse Like connect 4 in dagger terms
    4 Feb 2004
    85184,92352,75792,65584,40976,46592,
    38080,33992,8216,90120,82432,66080,38448,45088,44736,35008
    Its a good thing my work computer doesn't have speakers...............yet :worried:
    EDIT:
    As 500mph said, copying seems to lose a few of the notes. Except unfortunately on flibblesan's, that one was complete in all its pixelated glory............
  18. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    that is actually because it's using a pentatonic scale. It's difficult to get dissonance, especially when the parent is a major scale. Blues players use pentatonic stuff a lot.
    mine:
    73728,37376,18564,8224,4106,18448,9248,4096,65540,32832,17952,8194,4258,65826,66048,65538
  19. Prestidigitweeze
    14 May 2008
    Yes, of course. For the particulars, see my above post (though it sounds as if you wouldn't need to).
    For those who don't understand what Fod and I are talking about: Walk over to a piano or any other music keyboard, place your ring or index finger on the black key next to the lowest C you can reach, and run said digit across the black keys quickly from lowest to highest. The scale you'll hear is exactly the same as the one used by our illustrious flash sequencer. It is called a pentatonic scale because it consists of five notes rather than the usual seven. (A seven-note scale is called a diatonic scale.)
  20. Prestidigitweeze
    14 May 2008
    This sequence is a little piece of what is called a stretto: Lines of imitative counterpoint that follow one another more swiftly than in a normal passage in a fugue. If you listen, the middle voice -- C C E-flat F FGF G -- is the full theme. The top voice begins at the second half -- in a real stretto, it would play the complete theme and start before the middle voice. The lowest part is playing the same thing an octave lower, but twice as slowly. It, too, would play the entire theme if this were a complete stretto.
    33800,32772,32776,32896,1056,0,512,0,33056,32768,16,0,16648,16512,256,4096
    I've just tested it and all the notes are there.
