Adding A raid drive to an existing windows installation?
Discussion in 'Hardware' started by DETN8R, 15 Feb 2006.
  1. DETN8R
    DETN8R What's a Dremel?
    27 Oct 2001
    Im trying to add 2 drives in a mirrored raid configuration to my system. I've installed windows onto both of them. I did this to format the drives because I couldnt access them from windows on the other drive. Anyway I installed windows on the raid drive using the raid drivers and I can access my main hard drive from inside the raid windows installation but I cant access the raid drive from my main windows installation.
    Ive installed the raid driver through windows device manager and it still wont let me access files on the raided drive.
    I get this error "D:\ is not accessible. The File or Directory is currupted and unreadable"
  2. Adnuo
    Adnuo Banned
    28 Aug 2005
    I can't really understand what you're saying about installing Windows on the drives...But basically it sounds like the RAID isn't properly built. Rebuild it using an in-Windows utility if you want a software RAID.
    Having said that, is there a reason you're not using a hardware RAID?
  3. DETN8R
    27 Oct 2001
    it is hardware raid.
    I thaught that I coulndt see the raid drive because wasnt formatted, and the only way I could think to format it was to install windows on it with the raid drivers. Did this, booted up fine, I could even access my MAIN hard drive from this windows installation.
    Now, from my MAIN windows installation I can see the RAID drive but I cant access it, getting the error I mentioned above.
  4. DETN8R
    27 Oct 2001
    any takers?
  5. DETN8R
    27 Oct 2001
    forgive me for bumping this thread but I would really like some help with the matter
  6. *mat-ster*
    *mat-ster* What's a Dremel?
    10 Mar 2002
    Errrmmm........
    TBH - RAID for a desktop PC is not worth the hassle!!
    have you considered just installing your drives / OS as normal, RAID offers no real performance boost.
    Sorry it's not what you want to hear but i'mm afraid it's true...
    **UPDATE - sorry u want to protect your data - fair enough - give us your system specs etc...
    Matt :)
  7. DETN8R
    27 Oct 2001
    Im not going for performance here.
  8. DETN8R
    27 Oct 2001
    DFI LanParty UT NF4 Ultra-D. AMD 64 3500 1gb OCZ PC3700 Ram. Win XP Pro
  9. ridiculous
    ridiculous What's a Dremel?
    21 Jan 2005
    have you been to disk management yet
    right click my computer - manage - disk management format disk - quick format?
  10. DETN8R
    27 Oct 2001
    "Windows was unable to format the disk"
  11. ridiculous
    21 Jan 2005
    what controllers are your raids on?
  12. DETN8R
    27 Oct 2001
    what do you mean?
  13. ridiculous
    21 Jan 2005
    nevermind im really confused, it might be worth rebuilding your raid and restarting.
  14. Adnuo
    Adnuo Banned
    28 Aug 2005
    I really don't understand what you've done yourself to fix this. What hardware are you using? What RAID controller, what hard drives, SATA or IDE, how and when did you build the RAID, did you build it into a proper RAID1?
    You've left a lot of things unanswered for wanting help so bad.
  15. DETN8R
    27 Oct 2001
    Im using the onboard raid and utilities for configuring it.
    Sata Drives
