Build Advice Adding an external battery through the AC adapter entry , 19 +/- X VOLT ?
Discussion in 'Hardware' started by elglobie, 11 Aug 2009.
  1. elglobie
    elglobie What's a Dremel?
    11 Aug 2009
    I have a laptop (Samsung X360) that requires 19 V through the AC adapter entry.
    I want to add an external self-made battery through this entry.
    Since I will not be able to match the 19 V exactly, by how much lower/higher may the voltage deviate from the required 19 V ?
    Is it better to have 1V less than 1V too much ?
    Is it safe to experiment a little ? lower voltage , less risky than higher ?
    Is there a safety protection built in the laptop ? Only a fuse will blow up without more damage to the rest of the laptop ?
    Elglobie.:rolleyes:
  2. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    Lower is always safer than higher. (Although ±1V doesn't really make a difference.)
  3. elglobie
    11 Aug 2009
    What about +2V or -2V ?
  4. mm vr
    18 Nov 2007
    Propably should work just fine. But avoid if possible.
  5. elglobie
    11 Aug 2009
    What would be a safe way to test the limits up and down ?
  6. capnPedro
    11 Apr 2007
    A better question is why can't you match the 19v?
    If you can do +1/2v, why not slap a buck converter or something on it?
  7. elglobie
    11 Aug 2009
    Cells are 3.3 Volt
    I prefer not to use a converter because of losses.
    What losses do the best converters have ? Any link to those ?
    Assume I use 5 cells * 3.3 = 16.5
    6 cells * 3.3 = 19.8
    What converters can convert the above voltages to 19 V ?
  8. capnPedro
    11 Apr 2007
    You'd have to use an extra cell, then use a DC/DC buck converter.
    TBH though, 19.8v will probably be fine. If you're really worried, what's the current draw going to be like; you might be able to use a beefy zener diode.
  9. elglobie
    11 Aug 2009
    Draw will be around 1 Amp
