Adding more hard drives
Discussion in 'Tech Support' started by will., 29 Jan 2008.
  1. Acksaw
    Acksaw What's a Dremel?
    7 Jan 2008
    godmonkey, he is just going to do RAID0 so no need to warn.
  2. ch424
    ch424 Design Warrior
    26 May 2004
    No, you lose everything if one drive fails in RAID0 or JBOD. That's why it matters that he has backup.
  3. phillj
    phillj What's a Dremel?
    18 Jul 2007
    Am I missing something here, cut I thought JBOD stood for Just a Bunch Of Disks? Doesn't this just shows the disks individually? I know with Raid you get redundency (except for Raid 0, hence the 0) if the loss of data doesn't matter to you (backed up) then Raid 0 will give you the best performance.
  4. kenco_uk
    28 Nov 2003
    JBOD gathers all the disks you want to include and gives you, in effect, one disk. That's how I understand it, anyway. You can partition it as normal.
