Modding Adding more storage to your Asus Eee PC
Discussion in 'Article Discussion' started by Guest-16, 27 Dec 2007.
  1. frostymug
    frostymug What's a Dremel?
    26 Mar 2008
    I am thinking of doing something similar with a 30GB Ipod hard drive. Can this be done using the same USB cable from ipod? I am thinking that the small Toshiba HDD will fit inside the memory bay easily. Anyone tried this?
  2. mattthegamer463
    26 Nov 2004
  3. frostymug
    26 Mar 2008
    Just what I wanted...Thanks
  4. qrqba
    qrqba What's a Dremel?
    23 Jul 2008
    it would be a lot easier just to put your usb flash into your usb port....
  5. leemo
    leemo What's a Dremel?
    17 Aug 2008
    Hi. Having just got a asus eee pc 4g and having the same storage problems, and read the article above. My question is.... will it work with the Window Os or is it jist for the Linux Os and does it increase C drive memory or show as another drivewhen seen on "my computer" properties..Your help greatfully recieved.
    The size is great for what I need and I need more C drive storage as a master.
  6. mattthegamer463
    26 Nov 2004
    You can put windows on the EEE quite easily with an external CD ROM, and with a bit of work using a SD card.
    Any added storage like USB drives and SD cards are not part of your C:/ but you can use programs that will make them show up as part of C:/, I think. You may not be allowed to remove them after setting them up that way though.
    What I did was install the OS and updates to the SSD, and all my programs to an 8gb SD card. This gave me 1.5gb free on the SSD and everything worked great.
  7. rajee
    rajee What's a Dremel?
    2 Oct 2008
    Hi,
    I would just like to ask if this is applicable to my Eee PC 2G Surf? Really appreciate any help. Thanks
  8. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
    Should be applicable to any of the older EEEs, such as yours, for sure.
  9. rajee
    2 Oct 2008
    Thanks for the response CardJoe. By the way, I think I would be able to install Windows in the new drive and treat it as a primary drive.
  10. NDD
    NDD What's a Dremel?
    23 Oct 2014
    Hello,
    Give detail program that will make part of C:/
    Where is SSD in Eee PC 4? what is number of Ic. Can we replace this SSD with higher value say up to 32 Gb.
Tags: Add Tags
