Windows Adding prefix to multiple files
Discussion in 'Software' started by adidan, 9 Sep 2020.
  1. adidan
    25 Mar 2009
    Hey all.
    Just moved my OH over to a new phone and sd card. Moved the photos over that can be seen in the file system but only ones with an 'IMG_' prefix will show via the camera app.
    Anyway to add the 'IMG_' prefix to multiple files in W10 all at once rather than one by one?
    Cheers :thumb:
  2. Gareth Halfacree
    4 Dec 2007
    Go into Windows Subsystem for Linux, find the files, and type: for i in *jpg; do mv $i IMG_$i; done
    Use xargs if you want to speed things up.
    If you'd rather use command.com (or cmd.exe, whatever): for %a in (*.jpg) do ren "%a" "IMG_%a"
    If you're a PowerSheller: dir *.jpg | Rename-Item -NewName {"IMG_" + $_.Name}
    EDIT:
    Oh, but be aware that it'll happily work multiple times - so if you've files in there that already start with IMG_, they'll become IMG_IMG_. Could add a filter to remove any files starting IMG_ already; could just move 'em into a "done" folder first then move 'em back again afterwards.
    adidan likes this.
  3. wyx087
    15 Aug 2007
    adidan and MadGinga like this.
  4. MadGinga
    MadGinga oooh whats this do?
    19 Mar 2009
    wyx087 and adidan like this.
  5. adidan
    25 Mar 2009
    Cheers all, i'll give them a go later.
    Glad I asked, been fruitlessly googling like my gran this morning.
  6. adidan
    25 Mar 2009
    Had a spare 5 minutes and that worked a treat, thanks! :thumb:
    Not sure how i've missed this handy program over all these years.
    wyx087 likes this.
  7. RedFlames
    23 Apr 2009
    Install powertoys
    Code:
    winget install powertoys
    use PowerRenamer
    EDIT: late to the party but... meh...
    adidan likes this.
  8. adidan
    25 Mar 2009
    Thanks @RedFlames - Advancedrenamer did the trick but it's always handy to have options.
