News Adobe introduces GPU-accelerated Creative Suite 4
Discussion in 'Article Discussion' started by Tim S, 24 Sep 2008.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Langer
    Langer Jesse Lang
    24 Jan 2004
    Hoorah! Finally!
  3. SkiDave
    SkiDave Minimodder
    16 Mar 2008
    well thats gonna change my graphics card for my next build...
  4. biebiep
    biebiep What's a Dremel?
    12 Dec 2007
    So you need a quadro for the photoshop acceleration as well?
    Or does that work on a GTX280? It's not very clear from the article...
  5. Tim S
    Tim S OG
    8 Nov 2001
    Only the RapiHD plugin requires a Quadro.
  6. GoodBytes
    20 Jan 2007
    it uses nVidia CUDA, so the Geforce 200series is good. I don't know about the 8000 and 9000 series thus.
  7. Tim S
    Tim S OG
    8 Nov 2001
    All CUDA-enabled GPUs are fine
  8. Mo_
    Mo_ Did this world come by chance?
    7 Apr 2008
    I didn't even know it was coming! Looks good, just have to wait for that iso torrent :)
  9. TreeDude
    TreeDude What's a Dremel?
    12 May 2007
    Adding support for AMD's Stream processing shouldn't be very hard. Both CUDA and Stream are used for accelerating the same C code. Thankfully DX11 will end this divide once it is released.
  10. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    about time I say. I always figured graphics cards would do a much better job of rendering static images than the cpu in photoshop (can't speak to video editing, don't know anything about it).
    now it won't be the worlds slowest slideshow when editing high res photos and applying filters.
  11. Tim S
    Tim S OG
    8 Nov 2001
    Yep, for all intents and purposes the code should be reasonably portable between CUDA to Stream, but I believe there will be some minor code changes required in order to move it across seamlessly. As you say, the DX11 Compute Shader will solve all of this political garbage because apps will be seamlessly portable at that point as long as the GPU supports D3D11.
  12. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    ...wow. :nono:
  13. Langer
    Langer Jesse Lang
    24 Jan 2004
    :wallbash:
    break out the ban hammer.
  14. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    Because every one commenting here is going to go spend >£500 on photoshop....
  15. E.E.L. Ambiense
    26 Jul 2007
    ...some of us actually are professional graphic designers who do so....
  16. steveo_mcg
    26 May 2005
    But 95% aren't and i wasn't suggesting every one was going to pirate it...
  17. Silver51
    Silver51 I cast flare!
    24 Jul 2006
    I see Amazon has CS4 listed:
    £995.99 Adobe Photoshop Extended CS4 (PC)
    £207.99 Adobe Photoshop CS4 - Upgrade Edition (PC)
    The question is, what's the difference between the two boxes? Is one the full suite (Acrobat, Illustrator et al) and the other a PS standalone, or do Adobe really expect home users to pay £995 else suffer Photoshop elements?
  18. Langer
    Langer Jesse Lang
    24 Jan 2004
    +1. I'll be buying it for certain. No doubt.
    @Silver51 - One is an upgrade package for people who already own PS, you can pay a smaller fee to upgrade to the new edition.
  19. E.E.L. Ambiense
    26 Jul 2007
    Great way to go too. +1.
  20. Silver51
    24 Jul 2006
    Damn... I have CS2 at work, but I guess I'll have to stick with GIMP at home :(
    If it were around the £150 mark, it wouldn't have been so much of a problem.
Tags: Add Tags
