News Adobe releases patches for critical Flash, AIR vulnerabilities
Discussion in 'Article Discussion' started by Gareth Halfacree, 22 Aug 2012.
  1. Gareth Halfacree
    4 Dec 2007
  2. rollo
    rollo Modder
    16 May 2008
    the winner for the most patched program on earth
    Adobe Flash
  3. mi1ez
    mi1ez Modder
    11 Jun 2009
    The winner of the most patches still needed...
    lp rob1 likes this.
  4. lp rob1
    lp rob1 Modder
    14 Jun 2010
    Can we just leave Flash to die and move on to HTML5? Youtube has converted, but most other sites - like Flash game sites - still only use Flash. Adobe themselves are practically forcing people to stop using Flash themselves - dropping Linux support, removing the Flash app for Android etc. It seems that even Adobe want to get rid of this aging technology!
  5. PingCrosby
    PingCrosby What's a Dremel?
    16 Jan 2010
    'four memory corruption vulnerabilities, an integer overflow vulnerability, and a cross-domain information leakage issue'..... I only went to the GP for a check-up and this is exactly what he diagnosed me with as well
  6. dyzophoria
    dyzophoria Minimodder
    3 May 2004
    im guessing adobe knows this as well, they know flash is aging, until then they cannot do much but try to update it since a lot still uses it. ie6 cough* cough*
  7. GoodBytes
    20 Jan 2007
    When HTML5 will works properly, then you can suggest that. So far it doesn't, and crashes web browsers. Since YouTube implement HTML5 program, they can't visit youTube anymore as it crashes sometimes. Where they use Opera, Chrome or Firefox. I keep telling people to go to youtube.com/html5, and click to opt out, so that it uses Flash. And youtube isn't this exception. About all web sites that uses HTML5 videos creates headaches. HTML5 is extremely far from ready.
  8. MrJay
    MrJay You are always where you want to be
    20 Sep 2008
    Just finished imaging 600 odd windows 7 machines over 3 sites. 3rd year in a row Adobe have waited until we have just about finished with the yearly image before deciding its massively broken : (
  9. dicobalt
    dicobalt Minimodder
    21 Mar 2009
    Anyone else notice that Win8 refuses to update Flash for IE? The Adobe Flash download webpage tells me to enable compatibility view lists in IE (which already are enabled) but Windows Update doesn't install a new Flash like it is supposed to. If you manually download the Active X version of Flash it won't install in Win8. I wish I could say it was a software glitch only on my one PC but this happens in my desktop's virtual machines as well as on my laptop. So right now there is no way to manually update IE's Flash on Win8...
  10. Kacela
    Kacela What's a Dremel?
    19 Apr 2011
    This is a good thing, as it will only accelerate the development and acceptance of HTML5. I love developing in Flex/Air/Flash, but it's time to move on.
  11. Jhodas
    Jhodas Theorist
    4 Nov 2009
    That is a horrific list of vulnerabilities...
  12. Griffter
    Griffter What's a Dremel?
    1 Jun 2012
    3rd paragraph - "vulnerabilities that could case a crash", should it not be "cause a crash" :)
