Networks ADSL Router
Discussion in 'Hardware' started by acrimonious, 23 Mar 2003.
  1. Lazy
    Lazy Meow?
    13 Nov 2001
    fly don't make me take pics of my dlink dsl 504 and 16 port netgear switch :)
  2. Fly
    Fly inter arma silent leges
    31 Aug 2001
    I doubt very much that they cost £23 and £20 respectively though... ;)
  3. acrimonious
    acrimonious Custom User Title:
    8 Nov 2002
    I CAN'T GET IT TO WORK!!!
    I'm running Win2K with an Asus board with on-board LAN, any help?
  4. Fly
    31 Aug 2001
    The Computer system is irrelevant.
    What settings have you used and what ISP are you with?
    it would help if you had a second pc to talk to MSN me with while you set it up...
  5. acrimonious
    8 Nov 2002
    I've tried Bridge, Router, PPoP(or what ever)A and E.
    I'm with crappy BT
  6. Fly
    31 Aug 2001
    I'll screenshot my settings and post em....
    Mine works fine!
  7. Fly
    31 Aug 2001
    That works with BTOpenworld. If your settings are like this, it will dial. Proof is: I took the screenies while connected :p.
  8. acrimonious
    8 Nov 2002
    Fly you god you!
    I'm now posting through my new router. I set the IP to the default and not a different onen before, but now its fine.
    Thanks again.
  9. acrimonious
    8 Nov 2002
    MSN works fine.
  10. ASH
    ASH What's a Dremel?
    1 Apr 2003
    I've set up mine exactly as shown but it won't connect to BT.
    Help please
    Looking at the router status it goes from
    WAIT FOR ACTIVATING - debug code 8
    ACTIVATING - debug code 10
    IDLE - debug code 0
    I've tried changing the default address from 192.168.8.1 to 192.168.5.1 and no difference.
    The only difference I can see is that I'm on btclick.com not btinternet.com
    Any clues anyone ?
  11. Fly
    31 Aug 2001
    Hmmm...
    Sounds like an authentication problem.
    Is your password and username correct?
    Might be worth giving BT a ring to make sure u have got it all right!
  12. ASH
    1 Apr 2003
    same username & password I use for my bt intel modem. If i plug that in - it works.
    Should the router lnk light be on ?
  13. Fly
    31 Aug 2001
    from the manual:
    PWR: Router with proper power connection
    CD: ADSL Carrier Detect if LED is flash
    LNK: ADSL connection has been established if LED is on
    ACT: Router works properly with flashing LED
    TST: ADSL physical layer with uncorrected blocks if LED is flash
    Tx: Console port is transmitting data to PC
    Rx: Console port is receiving data from PC
    LAN: Ethernet twisted-pair port is connected if LED is on
  14. ASH
    1 Apr 2003
    hmm - RTFM always helps :)
    seems like I've got a duff one then - thanks for your help
  15. Fly
    31 Aug 2001
    np
    Shame. Good luck with E-Buyer CS.
  16. Moreland
    Moreland banned
    16 Jan 2003
    I have the Netgear DG814 it rocks :)
    You need to apply the firmwares to make it better tho.
  17. ned_solanki
    ned_solanki What's a Dremel?
    4 Apr 2003
    Got one of these as well, good bit of kit, but was wondering what do i need to check if the router needs to be configured so that I can VPN into work. We use a Cisco VPN Client, it goes thru, accepts my password and the stops on Checking Secure Channel. Is there someone simple like this router cannot be used with VPN. Any help please
  18. metz2000
    metz2000 What's a Dremel?
    22 Oct 2002
    Fly, that ADSL router you have (the one you linked to near the beginning of this thread costs £44.85 inc VAT)... how come it has jumped in price so much, was there an error in price or something? :sigh:
    I might still get it though, what do you think... good value still?
    Does anyone know if I will have any problems running this with Mandrake Linux? AFAIK all I need for Linux to work correctly with it is for the Linux box to have a NIC in it that is compatible with Linux... would that be right?
  19. Fly
    31 Aug 2001
    thats not a bad router, even for 45 quid. And a little birdy tells me that the one you get is actually the same look but with a different chip (a better one apparently).
    As for Linux, yeah it works just fine.
  20. metz2000
    22 Oct 2002
    So this is a modem and a router in one? All I'll need is a switch then :)
    4-port switch recommendations?
    Also, what NICs do people recommend? - cheapest possible (although I want something that will perform ok too ;) )
    EDIT: preferably I'd like the NICs to work with Linux if possible.
    EDIT 2: what's the difference between a switch and a 'managed switch'?
