Motors Advice for first car?
Discussion in 'General' started by TrevDX, 28 Mar 2015.
  1. TrevDX
    TrevDX Ah Who Cares Anyway???
    9 Aug 2011
    I'm after some advice.
    I'm currently doing my driving lessons (at the young age of 34) and have been looking at options for my first car for later this year.
    The thing is should I just look at buying a car to just do a year then sell/scrap it or should I buy a newer, but still under 4k car and look to try and keep for a while?
  2. Pieface
    Pieface Modder
    8 Mar 2009
    You're probably best looking at a second hand corsa, or Fiesta/Focus for that money if you want it to last a long time.
  3. TrevDX
    9 Aug 2011
    Yeah, what I was looking at was a 1.3 Fiesta but don't know whether to spend 4k on a 08/09 or <1k on a 99/00?
  4. Pieface
    Pieface Modder
    8 Mar 2009
    A 99/00 probably won't last that long. Old Fords are prone to a bit of rust and you might pay the value of the car getting it through it's next MOT. I've got a 56 Corsa which has had a LOT of work done to it (New suspension, engine, exhaust, everything mechanical pretty much), but thats because it's done 150k miles. Low mileage is very important in buying a new car, and a good service history.
  5. Anfield
    Anfield Multimodder
    15 Jan 2010
    Despite being 34 you will still be robbed blind by car insurance for the first 2 - 3 years, so just go with whatever is cheap, likely to last a year without any real repairs and in a very low insurance group.
  6. bsp
    bsp Minimodder
    25 Dec 2010
    Looked at older golfs/polos?
    Fairly solid car. Parts are easy to come by.
    +1 on service history. That doesn't just mean MOTs and stamps in a book but receipts as well!
  7. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
    Skoda!
  8. Kronos
    Kronos Multimodder
    6 Nov 2009
    Bugatti Veyron.
  9. MeddlE
    MeddlE Norwegian Blue
    23 May 2011
    Something cheap as you will ding it in the first year. Everyone does.
  10. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    It's one you can only really answer yourself but bear in mind that buying any car is a gamble.
    Personally, I'd rather go <£1k and if the worst happens that's all you're out of pocket. If you spend £4k on a car and the cambelt snaps and does £2k of damage then you're in trouble.
    Use the MAS cost calculator , it says my car will cost me £2k a year and it's probably right. Think about the odd unexpected bill, tyres, brakes and other consumables.
    If you're not too fussed the Ford Focus gets a good reputation and they're common as so parts are cheap and garages know them well. If you're handy you can do work yourself and save even more cash.
    Of course the simple answer to your question is a Volvo 240 estate.
  11. GaryP
    GaryP RIP Tel
    31 Aug 2009
    I hate Front wheel drive cars but I think spending <1k on a VW with a bit of history is the way to go, as you are likely to get most of your money back in a year.
    Stepson bought a 1.9Tdi VW Golf W plate 3 years ago for £1300. Has done 45k in it taking it up to 189k, hardly spent anything other than tyres brakes etc (locks was only bit that isnt wear and tear and he replaced the front seats for £50 from a scrappy). Just sold it for 1100.
  12. Pieface
    Pieface Modder
    8 Mar 2009
    Not everybody..
  13. Tichinde
    Tichinde Minimodder
    1 Sep 2010
    Indeed, my first 3 cars went undinged.
    Then I was involved in an incident (not my fault I will add!) which wrote off the forth :(
  14. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    passed in 97 and no dings for me. ***Touchwood***
    I say go for a Ford KA or Fiesta. Cheap for parts and easy to fix.
  15. ElThomsono
    18 Mar 2005
    I have to disagree with that, the KA is a rustbucket, not to mention a deathtrap and all round terrible car.
  16. Archtronics
    Archtronics Minimodder
    27 Jun 2006
    If your going to buy an older car don't be put off by mileage, often they will have had more parts replaced in comparison to a low mileage version, be sure to check the history.
    Personally my current go to work horse daily car is the clio mk2. I've had 4, my current one is a 1.5 diesal 80mpg and £20 tax. They can be easily found for 1k and are relatively cheap to repair.
  17. Harlequin
    Harlequin Modder
    4 Jun 2004
    pass plus - even at 34 will help as your a new driver.
  18. TrevDX
    9 Aug 2011
    Thanks for all the responses, I'll have a good look over all the cheaper cars for now :thumb:
    I was going to do Pass Plus as well after passing, always seemed like the right thing to do.
  19. Pieface
    Pieface Modder
    8 Mar 2009
    Pass Plus probably won't save the money to make it worth it at 34
  20. bsp
    bsp Minimodder
    25 Dec 2010
    If you are going down the VW route then VW/skoda/seat/audi are the same parent company but you'll differences in trim, engine power and insurance ;)
