Build Advice Advice need for i7 Build
Discussion in 'Hardware' started by happyhammer7, 8 Nov 2010.
  1. happyhammer7
    happyhammer7 What's a Dremel?
    19 Oct 2009
    Hi all,
    Just buying the last of my parts for my new build and need some advice.
    So far, I have brought the following arts -
    Intel Core i7 930 D0 SLBKP Bloomfield 45nm, 2.8 GHz, QPI 4.8GT/s, 8MB Cache, 20x Ratio, 130W, Retail
    6GB (3x2GB) Corsair XMS3, DDR3 PC3-12800 (1600) Non-ECC Unbuffered, CAS 9-9-9-24, 1.65V
    Gigabyte GA-X58A-UD3R Rev 2, Intel X58, S1366, SLi/Xfire PCI-E 2, DDR3 2200<, USB3 & SATA 6Gb/s
    Antec 1200
    Samsung F3 1TB
    Samsung CD Drive
    So nearly there so far, just need a PSU, video card, mouse, keyboard and some SATA cables for the cd/hdd.
    So far, I have selected the following to complete the build:
    Arctic Cooling MX-2 High Performance Thermal Compound (it's what arctic use on their Coolers)
    Logitech G15 New Rev.2 Gaming Keyboard, USB, Wired, Silver/Black, GamePanel LCD, Illuminated
    850W Corsair TX CMPSU-850TXUK PSU, 80+% eff', SLI/CrossFire, EPS 12V, 140mm Fan, 5 year Warranty
    45cm Akasa AK-CB055 Right angle connector SATA II cable inc Latch connector - Red/Black *OEM
    Razer Imperator, Gaming Mouse, Black, Laser, 5500dpi, USB £46.80 £54.99
    1280MB EVGA GTX 470, 40nm, 3348MHz GDDR5, GPU 607MHz, Shader 1215MHz, 448 Cores, 2xDVI,mini HDMI
    Does that look ok? I want to order the remaining parts tonight, so any advice is much appreciated.
    BTW, I have got a Corsair H50 as the cpu cooler and I am looking to overclock and add an additional video card in a year or so time.
  2. trig
    trig god's little mistake
    10 Aug 2006
    pretty high-end build. lots of choices that are...subject to taste, so to each their own. would go with the hx series corsair for the modular cables. i personally wouldn't splash for the 470 unless it's just a super sweet deal. too hot and power hungry. a 460 would be a little on the low-end side for this build, so maybe go with a 6870, or 2 gtx 460's in sli since that is your plan in the long run anyway...
  3. happyhammer7
    19 Oct 2009
    Cheers Trig, I did hear those comments about the 470 so decided to swap over to the 6870. What PSU would you recommend in the HX series? Would a 850w be enough?
  4. Big_malc
    Big_malc Minimodder
    7 Sep 2010
  5. happyhammer7
    19 Oct 2009
  6. happyhammer7
    19 Oct 2009
    I am also looking at adding a TV Tuner at a later stage (will replace TV in bedroom). Anyone have any good success with one within the UK?
    Thanks as always
  7. djzic
    djzic Bokehlicious!
    8 Nov 2010
    Happague's tv cards are always awesome...
  8. trig
    10 Aug 2006
    850 would be more than enough...so would 750 or 650 for that matter. either way it's a good choice...
  9. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    I never bother with TV tuner cards, just use iPlayer or torrent your favourite tv programs. Much more control that way. And dont get the sweaty 470 GTX, think 6850/6870/460 GTX :) Avoid overkill with the PSU, Corsair 750W modular is all you need.
