Build Advice Advice needed re choosing components for my new PC
Discussion in 'Hardware' started by Yukster, 15 Apr 2010.
  1. Yukster
    Yukster What's a Dremel?
    15 Apr 2010
    I chose the below components for my new PC upgrade (I have an ATX case and a PSU). But my knowledge is quite limited and I would appreciate your advice, particularly re the choice on CPU and Mobo.
    Intel Corei7 920 D0 SLBEJ Bloomfield 45nm, 2.66 GHz, QPI 4.8GT/s, 8MB Cache, 20x Ratio, 130W, Retail £163.17 £191.72
    Gigabyte GA-X58A-UD3R, Intel X58, S1366, SLi/Xfire PCI-E 2.0, DDR3 2200/1333, SATA 6Gb/s, RAID, ATX £129.17 £151.77
    4GB (2x2GB) Corsair XMS3, DDR3 PC3-10666 (1333) Non-ECC Unbuffered, CAS 9-9-9-24, DHX, 1.5V £101.98 £119.83
    60GB OCZ Technology, Vertex SSD, MLC-Flash, 2.5", 1 x SATA 3Gb/s, Read 230MB/s, Write 135MB/s £129.60 £152.28
    Titan Fenrir TTC-NK85TZ 120mm PWM 17dBA+ "HDT" CPU Cooler (775/1156/1366/K8/AM2/AM3) £24.98 £29.35
    1.5TB Samsung HD154UI Spinpoint F2 DT EcoGreen, SATA 3Gb/s, 32MB Cache, 8.9 ms, NCQ £62.97 £73.99
  2. Teelzebub
    27 Nov 2009
    I would go for the 930 intead of the 920 cpu and the i7 is tri channel memory so I would go for a 3x2gb 1600 ram kit.
  3. Yukster
    15 Apr 2010
    Thanks for your help. I really appreciate it :thumb:
  4. The Toy
    The Toy The Ticking Time-Bomb
    26 Feb 2010
    What he said. And yeah that motherboard is fine. Quite a nice set-up you are going for there! What is your budget and what will you be using it for?
  5. Yukster
    15 Apr 2010
    I don’t have a budget as such. I just chose what i liked and the whole PC is going to come to circa £800. I am going to use it for video editing, music ripping and office applications.
  6. Yukster
    15 Apr 2010
    Does anybody know what the different core names mean. The CPU on my list has a Bloomfield core but I don't know what it means and whether that's the best one?
  7. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
  8. Yukster
    15 Apr 2010
