Build Advice Advice needed to speed my pc up for Photoshop use
Discussion in 'Hardware' started by natward, 15 Dec 2009.
  1. natward
    natward What's a Dremel?
    15 Dec 2009
    Hi I'm after some advice as to what would be best to upgrade my PC to make Photoshop run better as with large files and many layers it takes too long to perform well.
    I was going to buy a new PC completely but think I maybe just spending money I really haven't got when there maybe something I could just upgrade to make it quicker.
    Here's my current spec machine
    Intel Core 2 Duo E6850 3.0 GHz 4Mb Cache
    6Gb Corsair Memory DDR 800
    500GB SATA Hard Drive partitioned 100GB as Photoshop Scratch disk
    8025-C43 Midi
    Atrix 720Watt Silent Dual Fan
    768Mb Nvidia 8800GTX graphics card DX10
    QC - Gigabyte N680iSLI-DQ6-1333fsb-DDR1066x4 SLI (Dual graphics)
    DVD+/- RW - 18X Samsung Lightscribe
    X-Discovery Case
    Windows XP64 Home
    I also have bought for it a
    VelociRaptor 300 GB fast Drive which is partitioned into 150GB parts and dual booted Operating system Windows XP64 Home on one and normal 32bit version XP home on the other
    BenQ FP241W 24in Widescreen Monitor.
    Any advice on what to buy if I had a budget of £300-700. I was thinking of getting a Crucial M225 64GB SSD drive and windows 7 but don't know if that would effect Photoshop speeds other than loading if I had my SSD drive with Operating system and programs on.
    Cheers
  2. Sir Digby
    Sir Digby The Supprising Adventures
    18 Jan 2009
    Photoshop CS4 to get GPU acceleration?
  3. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    photoshop should scream along on that machine.
    would i would do is setup another physical scratch drive, just buy a cheap HDD throw it in and point photoshop setting at it. Much faster than your partitioned space
    This way photoshop can dump large amounts of working related data to that drive and call upon it when needed, without the slow down of the OS doing background tasks on the drive.
  4. natward
    15 Dec 2009
    Hi yeah I had hoped it would scream along. forgot to mention it is Photoshop CS4 I have yes.
    If I wanted to get a new processor like say the Intel I7 920 to speed things up when I am doing Dreamweaver stuff too and other tasks as I think this is what slows it down when I have other things open.
    But would I then need a new Motherboard and a new case to fit it in.
  5. barndoor101
    barndoor101 Bring back the demote thread!
    25 Oct 2009
    why 6gb RAM? seems like an odd number for a C2D
  6. natward
    15 Dec 2009
    No reason really just all I could afford at the time, I didn't think I would need 8GB
  7. Teelzebub
    27 Nov 2009
    A i7 cpu is a different socket so yes you wuld need a new motherboard and new DDR3 ram
  8. MaverickWill
    MaverickWill Dirty CPC Mackem
    26 Apr 2009
    2x1GB, 2x2GB. Photoshop eats RAM for breakfast! ;)
  9. natward
    15 Dec 2009
    Without opening it I can't quite remember what it is, I think though I originally had 4 sticks of 1GB and I bought a 4GB kit of x2 2GB sticks and removed 2 of my originals 1gb sticks so making 6GB with all slots filled.
  10. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    As Burnout said above, a scratch disk would definitely see an improvement, especially if you use a small SSD like that Kingston. All you can do other than that is:
    Improve the graphics card, enable CUDA and get CS4
    Get a better CPU (E8400 or Q6600 would see a nice increase. If you can afford it the Q9550 would be really good, I've found Cache is more important than clock speeed/# of cores) and overclock it (you might need a new cooler, look at the Corsair H50).
    If you can afford it (and only if you can afford it) an i7 920 setup would eat photoshop for breakfast, but it'd probably take a good £400 up (Mobo, RAM, CPU, new case and cooler), though you'd still be able to afford another graphics card after that
    Have you thought about investing in a second screen?
  11. barndoor101
    25 Oct 2009
    ah i see, i just assume that everyone goes from 2gb->4gb->8gb when upgrading.
    would an extra 2gb make a noticeable difference?
    other than that an SSD or dedicated scratch drive would make the most difference short of a complete upgrade (core i7 etc).
  12. natward
    15 Dec 2009
    Yeah if I stick with my motherboard I guess the CPUs you mentioned are my way to go, its just I guess for future proofing it more I think a year down the line I might think I'd regret not going the full i7 setup and new case and motherboard and DDR3 RAM. Its worth considering though, thanks for the suggestion.
  13. natward
    15 Dec 2009
    Yeah I could get a cheapest kingston ssd drive dedicated to scratch and see if it improves.
    God I'm really bad at making decisions lol. Part of me wants to go the full hog and build my dream machine
    AMD Radeon HD 5850 1GB GDDR5
    Intel Core i7 920 but have it overclocked to 4GHz
    Asus P6T Deluxe V2 motherboard
    6GB Corsair DDR3 1600MHz C9 Triple Channel
    Antec P183 Case
    Antec CP850
    Intel X25-M 80GB
    Samsung Spinpoint F3 1TB hard disk for storage
    LG GH22NS50 SATA DVDRW (I'd still recommend a 24x Sony instead at no extra charge )
    Windows 7 64 bit Home Premium
    Thermalright Ultra 120 Extreme
    I could then try and sell my current machine, its just its only 2 years old, seems mad to buy a new PC every 2 years.
    Thanks anyway guys for giving me something to think about the options on making Photoshop run better.
  14. bigsharn
    9 May 2008
    -doesn't support CUDA, and I don't think it supports acceleration for photoshop (which is why I have a 4850, it's in the list of compatible programs, see here)
    Antec CP850
    -I'd get a Corsair HX650 myself, but each to their own
    Intel X25-M 80GB
    -damn powerful, but also damn pricey
    -I'd get a H50 myself but each to their own
    Just my opinion on your dream rig, as for the case that's purely to taste :p
  15. barndoor101
    25 Oct 2009
    im pretty sure that gpu accel for photoshop uses OpenGL not CUDA
  16. cyrilthefish
    cyrilthefish What's a Dremel?
    15 Apr 2004
    I think so too.
    If i leave fraps running by mistake, you even get the onscreen FPS meter showing up in photoshop :hehe:
  17. bigsharn
    9 May 2008
    yeah, openGL with ATi cards and it uses Cuda on NVidia as well, I'm sure of it
  18. barndoor101
    25 Oct 2009
  19. natward
    15 Dec 2009
    Sorry you've lost me a little . Will the AMD Radeon HD 5850 1GB GDDR5 not be much good for Photoshop CS4 then. I only opted for this as thought it would be a little more future proof when more dx11 games are released.
  20. MaverickWill
    26 Apr 2009
    It will, as Adobe decided to use a standard that both cards support.
    As for games, wait for Fermi if you're plumping for something solely on DX11.
