Build Advice Advice on ~£800 pc component list
Discussion in 'Hardware' started by Confused Fishcake, 14 Jul 2012.
  1. Confused Fishcake
    Confused Fishcake Member
    25 Sep 2005
    Hi, I'm looking to scratch build a decent pc for around £800 between now and christmas. I'm willing to wait a bit if it'd be better nearer christmas. These are the components I've picked out so far (from ebuyer):
    HannsG HL249DPB LED LCD 23.6" DVI Monitor £107
    Gigabyte GTX 560 OC Edition 1GB GDDR5 Dual DVI Mini HDMI PCI-E Graphics Card £136
    2 x G-Skill 8GB (2x4GB) DDR3 1600Mhz RipjawsX Memory Kit CL9 (9-9-9-24) 1.5V £80
    OCZ 500W CoreXStream PSU £35
    Casecom 6788 All Black Case £30
    Corsair 120GB Force 3 SSD - SATA-III 2.5" - Read 550MB/s Write 510MB/s 85K IOPS Fast Performance 3YR Warranty £80
    Intel Core i7 3770K 3.5GHz Socket 1155 8MB Cache Retail Boxed Processor £256
    Gigabyte GA-Z77-D3H Socket 1155 VGA DVI HDMI 8 Channel Audio ATX Motherboard £78
    So that's about £802 so far (ok for me). Now I haven't put cables/fans/mouse/keyboard, because I have most of those. I also don't want/need optical drives, and as for storage, I'll add a 2tb hard drive later when I have more money (my netbook has 650GB so thats ok for now.) I want this pc for:
    3d rendering
    being able to play any game released in the next few years, even if its at low settings
    virtualising win8/ubuntu without feeling sluggish
    Compiling large c++ projects quickly
    DX11 programming
    I'm coming from only having an eeepc netbook, so this should be a /bit/ of an improvement. My main questions are:
    Is the GTX 560 going to last me a fair while? (it looked like the best value for money)
    Is the PSU beefy enough?
    Is there anything weird I should know with 16GB of ram? The motherboard says up to 24GB in the 4 slots, so I think I'm good.
    Can I save any more money on the case, or is that the least I can spend and have an acceptable one? (I don't mind 3d printing replacement bits if they break or anything)
    Is the SSD ok-looking (tbh, that's something I can research just before I buy)
    Is the i7 I picked worth the extra over a cheaper chip? I want hyperthreading, so I think that means I want an i7, and this one looked very nice.
    Is the motheboard ok for at least basic overclocking?
    I would probably be looking to overclock in a few months when I can buy abetter cooling system, but the headroom to do so if I wanted would be nice.
  2. Edsterr
    Edsterr New Member
    27 Apr 2012
    You may be better getting a non overclocked graphics card to save you money, then you can overclock it yourself. Besides that it all looks fine
    Just out of curiosity: where are you buying from?
  3. Confused Fishcake
    25 Sep 2005
    I was looking at ebuyer.com. As for the graphics card, it's only £5 cheaper for a gainward (haven't heard of them?) card that gets a lot hotter, so I was going for the OC one just for a better cooling system.
  4. Edsterr
    Edsterr New Member
    27 Apr 2012
    Is there not a card by the same company but not already OCed?
    It might also be worth checking Scan.co.uk for your components
  5. Confused Fishcake
    25 Sep 2005
    Not on ebuyer, but i'll take a look at scan - the prices seem very similar but saving a few pounds would be nice. Thanks :)
  6. murraynt
    murraynt Well-Known Member
    6 Jun 2009
    It looks pretty solid mate.
    This screen is a tiny bit more expensive but it's worth it.
    http://www.ebuyer.com/284103-lg-ips235v-ips-lcd-led-23-hdmi-monitor-ips235v-bn-aek
    Regarding the case, it's not a great case. Don't go any cheaper. Personally I would be spending a tad more. Maybe 45 pounds on one.
    Nothing worse than have a great pc but a cheap case. It's kind of like having an expensive suit but wearing reebok trainers with it.
    what software are you using for rendering? Make sure it can utilize all the 8 threads on the chip.
  7. Confused Fishcake
    25 Sep 2005
    I went for that screen, does look nice, but kept the case - I'm already spending waaay more than I should, and I'll probably hack it to suit me or something. As for rendering, I'm going for blender,openscad,zbrush, a few others, only a couple actually do multithreading, but i'm going from an eeepc so it should be an improvement.
  8. lm_wfc
    lm_wfc Member
    18 Feb 2011
    What sort of 3D printer do you have access to???
  9. Confused Fishcake
    25 Sep 2005
    I have a reprap prusa2, and a second one nearly complete :) Best thing I ever made, I can't recommend them enough.
