Networks advice on purchase please
Discussion in 'Hardware' started by Whitlog, 4 Jun 2009.
  1. Whitlog
    Whitlog What's a Dremel?
    26 Jul 2004
    Hey
    I have a Netgear WPN111 for my PC and It is awful, It gets so hot and cuts out a lot!.
    So I do not make the same mistake I would like advise on good Network adapters please
    Thanks :D
  2. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    Haha, I remember somebody said "Netgear stuff overheats" something like a year back! Seems like that was true. :D
  3. Whitlog
    26 Jul 2004
    It heats up so fast as well, It is crazy how much it disconnects from the router also.
    I really need a knew adapter, any suggestions?
  4. adam_bagpuss
    24 Apr 2009
    Abit Airpace PCI-E wireless card.
    about £10 from scan used it in a couple of builds been great so far.
    it has a little antenna with a cable rather than just an antenna sticking out the back which makes for much better signal.
  5. Whitlog
    26 Jul 2004
    great will get one after work! Cheers
