advice on RAM for $80-100 max
Discussion in 'Hardware' started by webbyman, 26 Nov 2004.
  1. webbyman
    webbyman Hax.
    7 Oct 2004
    i need some ram for my new setup along with everything else i took back the ram i previously brought as i realised it wasent up to scratch :hehe:
    im going to spend about $80 (pounds) hopefully on some good ram :dremel:
    its not an amasing amount of money...
    anyone got some suggestions?
    and would it be a good idea to go for something like dual 265mb ram as my mobo will be dual channel... (well i think :dremel: )
    thanks :D
  2. webbyman
    webbyman Hax.
    7 Oct 2004
    :worried: is this good?
    Corsair 256MB DDR2 XMS2-4200 (MY-051-CS) £35.25
    and
    Corsair XMS3200LLPT TwinX (2x256MB) Platinum CAS2 £70.50
  3. Firehed
    15 Feb 2004
    First stuff is DDR2 so unless you have an LGA775 system it won't work.
    Second kit is quite nice as long as you don't plan on overclocking. Cas2 is always a nice bonus.
  4. webbyman
    webbyman Hax.
    7 Oct 2004
    i know the ddr2 wont work but its pretty cheap isnt it...
    and why wont the second stuff overclock very well...
    i proberly wont be overclocking or will but only by a little.
    :dremel: anyone else got ideas on ram for about $80?
  5. iljs
    iljs What's a Dremel?
    31 Jul 2004
    Muskin II bh-5 ... 512stick :). By far the best ram of all time and i believe muskin is selling their refurbished RMA'a on their site :). They've been shown to hold 2-2-2 close to 300 at 3.7 :)
  6. webbyman
    webbyman Hax.
    7 Oct 2004
    lol whats their website address... i cant find it :hehe:
  7. tmod
    tmod What's a Dremel?
    9 Apr 2004
    Lol...he said he wasn't overclocking, BH-5 isn't gonna be too cheap either. :)
  8. Tim S
    Tim S OG
    8 Nov 2001
    The Corsair LLPT that you are looking at there has CH-5 DRAMs, at least, they used to, and most likely still do now. They don't overclock very far, because that is typical of CH-5 - it doesn't hold timings very well unless you give it a lot of volts.
    I reviewed the 1GB kit of 3200LLPT over here: http://www.bit-tech.net/review/330/
    The Corsair modules' detailed results are on this page: http://www.bit-tech.net/review/330/4
    There are other memory reviews floating around which are worth the read - the 256MB modules are typically slightly better overclockers than their 512MB siblings.
    We're comparing all modules that we've reviewed every time, which means that we end up with a great selection of results enabling us to find the best-performing memory modules around.
    Corsair 3200XL: http://www.bit-tech.net/review/339/
    Mushkin LII R2 & OCZ Gold Rev 3: http://www.bit-tech.net/review/349/
  9. webbyman
    webbyman Hax.
    7 Oct 2004
    i will proberly go with the
    Corsair XMS3200LLPT TwinX (2x256MB) Platinum CAS2 £70.50 :hehe:
    seems quite cheap and im not realy going to be overclocking my pc by much if i do. i will proberly overclock my 1.8ghz amd64 3000+ to about 2.0->2.2
    of corse with help from some people. :dremel:
