Build Advice Advice on this gaming rig?
Discussion in 'Hardware' started by eXtremejt, 17 Jun 2010.
  1. eXtremejt
    eXtremejt What's a Dremel?
    17 Jun 2010
    Hello. I'm hopefully going to buy this specification in a few weeks; I just wanted to know what you guys think about it and is there anything that should be changed or added?
    Main Purpose: Gaming
    CPU: AMD Phenom II X4 955
    CPU Cooler: Xigmatek Dark Knight
    Motherboard: Gigabyte GA-890GPA-UD3H
    RAM: 4GB Corsair XM3 DDR3 1333MHz
    GPU: 1GB Asus 5850 4000MHz
    PSU: Corsair 550W
    HDD: 640GB Western Digital Caviar Black SATA 6Gb/s 7200rpm 64MB cache
    DVD/R: Samsung SH-S223C 22x
    OS: Microsoft Windows 7 64-bit
    Case: Coolermaster 690 V2
    Also, what size monitor would you recommend with this rig?
    Thanks, much appreciated. :thumb:
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Not sure about the cooler, but everything else seems ok :) Maybe a Titan Fenrir would be better?
    Drop the WD for a Samsing F3 1TB, its much better :)
    22-24" monitor would do you, how much did you want to spend?
  3. Telltale Boy
    Telltale Boy Designated CPC Jetwhore
    3 May 2010
    ^+1
    The Dark Knight is a decent cooler but i'd go with the Fenrir for about £5 more & he's right about the Samsung F3.
  4. murraynt
    murraynt Modder
    6 Jun 2009
    and a 22 inch monitor should suit that 5850 perfect a BenQ g2220hd is a good one recommended by bit-tech and custom pc
  5. seanbean
    seanbean Certa Cito
    21 Apr 2010
    +1 for the Samsung, hard to get much better unless you go SSD - see here.
  6. eXtremejt
    17 Jun 2010
    Ah ok, thanks for the replies - very helpful indeed. I was told that I should not go higher than 1680x1050 native resolution for gaming; is this true?
  7. eXtremejt
    17 Jun 2010
    Also, is a 500GB Samsung F3 Sata 3Gb/s 7200rpm 16MB cache worthy in my rig? I can't see myself using 1TB.
