Advice Sought Please
Discussion in 'Hardware' started by D1662, 26 Nov 2005.
  1. Hiren
    Hiren mind control Moderator
    15 May 2002
    2 512mb PC3200 sticks would be the best, however your CPU is only running 533 fsb so I wouldn't worry about it too much. PC3200 is mostly for 800fsb CPUs,
  2. Guest-16
    Guest-16 Guest
    The thing is the P4 CPUs which your celeron is based on need a large cache to stay competative in performance. It's just due to how they are designed. The celeron uses a really small amount of cache to be cheaper but that cripples it and so to get any proper performance out of it you need a LOT of memory bandwidth, so the faster your memory is the better.
    Go ahead with your PC2100 and see how you like it. I wouldnt be supprised if you dont notice much difference so it's probably not worth the effort spending out just yet.
  3. D1662
    D1662 What's a Dremel?
    26 Nov 2005
    Start Again !!!!!!!!!!!!!!1
    The current CPU in my PC is as follows.
    CPU Properties:
    CPU Type Intel Celeron, 2600 MHz (26 x 100)
    CPU Alias Northwood-128
    CPU Stepping D1
    Instruction Set x86, MMX, SSE, SSE2
    Original Clock 2600 MHz
    Min / Max CPU Multiplier 26x / 26x
    Engineering Sample No
    L1 Trace Cache 12K Instructions
    L1 Data Cache 8 KB
    L2 Cache 128 KB (On-Die, ECC, ATC, Full-Speed)
    CPU Physical Info:
    Package Type 478 Pin uPGA
    Package Size 3.50 cm x 3.50 cm
    Transistors 55 million
    Process Technology 6M, 0.13 um, CMOS, Cu, Low-K
    Die Size 131 mm2
    Core Voltage 1.525 V
    I/O Voltage 1.525 V
    Typical Power 52.8 - 68.4 W (depending on clock speed)
    Maximum Power 67 - 87 W (depending on clock speed)
    CPU Manufacturer:
    Company Name Intel Corporation
    Product Information http://www.intel.com/products/browse/processor.htm
    CPU Utilization:
    CPU #1 0 %
    :idea: And I am wishing to up grade to the following CPU. :idea:
    :wallbash: I have recently purchased a Intel Celeron D 345, 478 Pin
    3.06 GHZ,256KB Cache 533MHz FSB UP ONLY CPU.
    :duh: Please could you advise on what motherboard that you would recommended, as the current motherboard will only supports 2,60 GHz at 400 FSB CPU's. :duh:
    :idea: That is why I was asking on which motherboard that you would recommend for me to be able to use the larger CPU.:eyebrow:
    I thank you for your time in this matter. :thumb:
    Regards.
    Terry
  4. hitman012
    hitman012 Minimodder
    6 May 2005
    The aforementioned Asus boards would be suitable. Asus is a quality manufacturer who makes pretty good mobos :)
  5. Hiren
    15 May 2002
    I'd still recomend either the Asus P4P800 / P4C800 series or the Abit IC7.
  6. D1662
    26 Nov 2005
    Current Motherboard
    :sigh: I have looked at the motherboards that have been mentioned, but there is a problem that they all have 5 PCI slots, the current motherboard only has 3. :sigh:
    :idea: This link will take you through to a picture of the current motherboard.
    http://www.macavoyt.freeserve.co.uk/mb03701.jpg :dremel:
    :read: If I read things right this mean that I shall have to by a new case to put one of the aforementioned motherboards in. :confused: :confused:
    Regards.
    Terry
  7. Guest-16
    Guest-16 Guest
    Doesnt matter, unless your case can only hold a motherboard with 3 PCI slots (micro ATX), one with 5/6 is called a full ATX.
    You will need to reinstall your OS, whatever mind.
  8. Hiren
    15 May 2002
    Sounds like you've got a matx board and maybe case? In that case go for the Asus P4P800-vm which is the micro atx version of the boards I mentioned.
  9. D1662
    26 Nov 2005
    RAM Chips
    :idea: I have currently 2x512MB DDR PC2100 strips in this current motherboard, I also have 2x256MB DDR PC2100 strips spare. will these chip sets work together in this Asus P4P800-vm motherboard. :dremel:
    Regards. :wallbash:
    Terry
  10. Hiren
    15 May 2002
    That ram should work fine in that board.
  11. D1662
    26 Nov 2005
    Any thing else I should.
    Thank you for the help and advice that you have imparted.
    :duh: Will I have to reinstall the OS, as I have HD one for seldom used and the other one has the programs that run the PC. :duh:
    :confused: Could you listed in series of steps on to how to go about it so that I can get it right. :blah:
    :thumb: I am on broadband so I could make redundant the dial up modem. :thumb:
    Regards.
    Terry. :sigh: :clap:
  12. D1662
    26 Nov 2005
    RE; 6600 256MB/DDR
    :read: I today installed the above mentioned Graphics Card and it works brillent with no problems, the graphics are impressive to say the least. :hehe:
    Regards.
    Terry.
  13. ridiculous
    ridiculous What's a Dremel?
    21 Jan 2005
    ive got the same setup would recommend it to you aswell, so long as you dont plan on upgrading your video cards anytime soon.
