AeroCool Hercules HSF from Chill-Tek
Discussion in 'Article Discussion' started by :: kna ::, 3 Dec 2002.
  1. :: kna ::
    :: kna :: POCOYO! Moderator
    15 Mar 2001
  2. Cheese
    Cheese Doc
    6 Oct 2001
    I'm sure 500g of copper must cost a fair whack, I don't know how they can afford to make these things so cheap... bargain :)
    Rob.
  3. Kevo
    Kevo 426F6C6C6F636B7300
    9 Sep 2001
    I like the packaging :D
  4. Fly
    Fly inter arma silent leges
    31 Aug 2001
    Man, thats one heavy heatsink to put a single clip on!
  5. [GiB] Spawny
    [GiB] Spawny Xqpack Lovin
    2 May 2001
    Great review as always Kna :clap:
    Did I miss in the review about noise, something that is important this days :naughty:
    Just interested how it faired against the others?
  6. :: kna ::
    15 Mar 2001
    Hmm, I did mention it (about the silence solution) although admittedly not in comparison.
    That said, another review coming out today might see to that. :)
  7. aCe2k
    aCe2k What's a Dremel?
    1 Jan 2002
    Jess, now i dont understand anything...
    Got a XP2100 with the same cooling as Macroman has in his article: Titan Aluminium Fan ( http://www.bit-tech.net/review/147/ )
    Atm, 2 case fans blowing in fresh air and psu blowing it out...
    Installing Blowhole in a few hours, but still my cpu run's at 52'C with side door open... Can there be something wrong with my CPU ? or mobo detecting wrong voltage?
    With case door closed, i'm idle at 58'C and 100% i havn't tested as i don't dare... :/
    all though shutdown is set in bios at 70'C. I just don't understand it.. have tried it with 5 different heatsinks and fans from a 31cfm papst fan to the monster from Delta...
    though the delta did get the temp down to 43'C at idle, 51'C @ 100% running at 12V or as i like to call it... THE JET
    I still think something is wrong.. ( room temp 22'C ).
    Another thing i keep putting my brain to is actually where on the heatsink these fans blow the air... ( allways to the sides ) as the motor on the fan is center mounted.
    Anyone tried mounting a fan on a cone/bevel? Where as the air will be forced to the center of the heatsink where the actuall heat is located..
    But still i think something is wrong with my cpu...
    Allways 10-15'C above everyone else... :/
  8. essjaytee
    essjaytee emtarkanderundergunderson
    11 Jun 2002
    Nice job, I wish it had better mounting facilities though... that's a might heavy lump of copper to be suspended by two thin plastic tabs.
    I'm pedantic too, and I only found one typo :)
    Last Page:
    "The results were quite interesting, as the Hercules is very, very ahead in it's cooling capabilities: "
    Should read "its cooling capabilities: "
    I'm available for "official Bit Pedant" if that office is not filled :)
  9. Digitalblueshift
    Digitalblueshift What's a Dremel?
    12 Feb 2002
    hmm seems like a good replacement for my fathers and mine wbk-38's, We are getting a little bit deaf over here...
    Am I right in looking at a 50% noise redux from my 45 dB delta black label?
    hmmm one lug, definetly a three lug mod job coming up am I right KNA?
Tags: Add Tags
