Reviews Aerocool P7-C1 Pro Review
Discussion in 'Article Discussion' started by bit-tech, 19 Oct 2017.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    Hold on, is this a rebranded Antec P8 chassis with some plastic parts and lights thrown on?
    Looking at all the details the main chassis is identical, the build quality also sounds very similar.
  3. Anfield
    Anfield Multimodder
    15 Jan 2010
    Definitely using internals sourced from the same OEM (or a "borrowed" design)
    Differences from comparing photos:
    Plastic tat on outside
    No Antec logo on PSU shroud
    HDD mount located under PSU shroud is at a different height
    Different fan cut out in roof
    Everything else?
    Same mainboard tray including identical punched design shapes, same cable management bulge, identical SSD mounts, identical expansion slot blanks and so on.
  4. Mr_Mistoffelees
    26 Aug 2014
    So they are charging an extra £50 for a tarted-up £60 case. (Amazon price for the Antec P8)
  5. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
    Yep, it definitely is. Good spot, guys! In fact, after putting this case away, I got the P8 for review (incoming next week) and had a serious sense of déjà vu!
    MLyons likes this.
Tags: Add Tags
