Hardware Aerocool V12XT Review
Discussion in 'Article Discussion' started by arcticstoat, 17 Dec 2011.
  1. arcticstoat
    arcticstoat Minimodder
    19 May 2004
  2. DevilsShooter
    DevilsShooter What's a Dremel?
    3 Nov 2011
    Ha nice one, just saved me £40. Was looking for a review on that, reminds me of the old zalman I had with a lcd screen that you could only view when sitting on the floor directly opposite the pc. What would you recommend for a fan controller for x5 120mms?
  3. law99
    law99 Custom User Title
    24 Sep 2009
    It looks a bit like it was made by someone who was responsible for car dashboards in the 80s
  4. GaryP
    GaryP RIP Tel
    31 Aug 2009
    I have an Aerocool Touch1000 and it has none of these problems and costs less. No way to turn the screen off but my case has a door !
  5. SolidShot
    SolidShot Minimodder
    8 Jul 2011
    No one can make a decent touchscreen fan control it seems. If i win the lottery tonight, im gonna set up a business making proper bits for gamers by going through bit tech, reading whats **** and then improving it :)
  6. Xir
    Xir Modder
    26 Apr 2006
    Do this, the touch 1000 or the touch 2000 spin up to max on boot? (for cleaning the fans)
    Does the touch 1000 or 2000 allow for gradients on fanspeed?
    The viewing angles are supposed to be this way according to the aerocool website.
  7. dream1
    dream1 What's a Dremel?
    26 Feb 2011
    "SolidShot" U r right about that i think for that money what ever they are selling is crap for me if i ever gona use any system for light, fan, pump etc i would just jus simpel DMX interfase the best thing ever for controlling somthing. http://www.enttec.com/index.php?main_menu=Products&prod=70304&show=description <<< usb to dmx would look like something that.. If somebody dosent under stand what i am tolking about go to googel and read more about dmx lighting. So i think this would be the best for me :D.
  8. SMIFFYDUDE
    SMIFFYDUDE Supermodders on my D
    22 Apr 2009
    That DMX looks like the internet from the IT Crowd
  9. adidan
    25 Mar 2009
    Looks a bit fugly, not sure why they have to try and make everything touchscreen just for the sake of it. I mean once I found the sweet spot for all the fans they remain set, I don't need to keep tinkering with them so I've never seen the point in a massive screen to control fans.
    TBH I prefer my bog standard twiddly knob, so to speak.
  10. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    I had similar problems with an NZXT Sentinel LX a little while back. While the idea behind large LCDs and touch sensativity for fan control seems cool and futuristic, it's ultimately futile when you're basically just using fan controllers like toggle switches. Especially when before each gaming session you have to tap unlock, the fan you want, and then plus about 20 times.
  11. ya93sin
    ya93sin What's a Dremel?
    18 Oct 2011
    Lamptron FCT (Fan Controller Touch)
    Bought one and it doesn't let me down, and it works beautifully, just it will hit your wallet a bit harder than the Aerocool on review.
  12. Somer_Himpson
    Somer_Himpson What's a Dremel?
    22 Jan 2010
    I recently installed this unit in my Lian Li 7fnw case and my experience of it is quite different to the review.
    You can only see the screen template when it is off.
    The display is crisp and clear and the touch screen is absolutely fine...I can only assume this was reviewed very quickly.
    My PC sits on the desk just to the right of where I sit and the viewing angle is spot on.
    I would recommend this unit and can post pics later on forum to prove it is just fine.
    56% is an unfair score IMO
Tags: Add Tags
