On the Cooling section in the bit-tech website i found some test results of several coolers. Here is the link http://www.bit-tech.net/hardware/cooling/2009/05/17/titan-fenrir-ttcnk85tz-cou-cooler/4 In it for the coolers the temps are very low. For example the idle tem wit the titan fenrir is around 17C and load temp is 35C. Is it possible And what is this delta T mentioned on that page? What was the room temp when they did these tests? My room temp is between 26-32C. If i use a titan fenrir on a Q6600 what do u think my temps will be?
It's possible but here in the UK it's a lot cooler than in Sri Lanka, not sure what the temps are in the B-T labs so I can't give an estimate as to the actual temps... but 17 C is definitely plausible here
All the temperatures in those graphs are the difference between the room temp and the temp of the item. That means that if the room was 20 degrees then the idle temp for the Fenrir was 37, and 55 for the load temp. If the room temp was 30 then the CPU temps would be 47 and 65.
ive got an overclocked phenom 2 550 BE with a titan fenrir and idle's bellow 20c, load no more than 35c, it is quite cool in the uk though.
