News Ageia outlines plans for PhysX
Discussion in 'Article Discussion' started by Tim S, 22 Feb 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. DougEdey
    5 Jul 2005
    Still no use for them IMHO.
    Taken from Ageias hidden plans:
  3. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    I think that this is a better option than using a GFX card to do it. Just think how much power 8800GTX SLI uses, not to mention R600 (which is rumored to be more power hungry) And they want us to use a third to do physics? I would prefer to go the PhysX or CPU route.
  4. TheSaladMan
    TheSaladMan What's a Dremel?
    15 Sep 2006
    I think the entire concept of a PPU came too late, with multi core processors becoming more common these days there's just gonna be no point in having a dedicated PPU to do your physics when you'll be able to dedicate one or two of your CPU cores to it sooner or later.
  5. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    the only saving grace for these will be unreal tournament 3 if this does indeed use the ppu then i could see thsi working however if not it will fail
  6. Omnituens
    Omnituens What's a Dremel?
    5 Apr 2006
    waste of a mobo slot tbh. already hard to come by.
  7. randosome
    randosome Banned
    17 Sep 2006
    now that their opening it up a bit with a SDK may finally allow this to take off
    ATM there just is not enough support for PPU's and that is what will kill it, hopefully they will succeed eventually, if they increase support and drop prices i can see this working
  8. Tyinsar
    Tyinsar 6 screens 1 card since Nov 17 2007
    26 Jul 2006
    I thought this was dead already. Plus as others said, yes this is better than using the GPU but do multi-core systems really see any benefit?
  9. Nikumba
    Nikumba Minimodder
    29 Aug 2001
    Great product but not real DX support, if they had MS include their API into DirectX they would have a much larger customer base IMHO
    Kimbie
  10. atanum141
    22 Jul 2004
    Na mate, the GFX card option is better as there would be lot less code and drivers added into the equation, also similar hardware allways works best together most of the time.
    I prefer the idea of having two 8800GTX's in sli and using a old Geforce4 to do the physics calculations, same goes for the ATi camp. just using a old card would be enough power for any of the physics calculation's, that means more money for the firms but not at the rate Ageia is asking for its POS.
    Funny thing is that theres a thread i made last year about the Ageia demo, and even without the card it would run the demo, i was on SktA last year and i had miniumal overheads when running in software mode, even i believe that Bit-Tech or someone did a test on games that used the card like GRAW and showed no improvement or extra "wow" factor other than the extra cost to the end user.
  11. Baz
    Baz I work for Corsair
    13 Jan 2005
    the rise of dual and quadcore CPUs has killed physx where it stood.
    Why spend £100+ on a physx card when you have a 2md/3rd/4th CPU core sat idle?
    Company of Heroes for instance, uses the 2nd core to handle its physics in multicore machines.
  12. Kipman725
    Kipman725 When did I get a custom title!?!
    1 Nov 2004
    erm seen the physics in alan wake? thats using a quad core cpu not a phyisics card or special GPU drivers. The whole phyisics card idea and using graphics cards for phyisics (at least in games) is dead with the rise of multi core cpus.
  13. EQC
    EQC What's a Dremel?
    23 Mar 2006
    For those of you who think an extra core on a CPU can do the physics that a PPU can do: you're very likely wrong. You can successfully argue that the physics YOU are looking for in games could be done on the CPU...but the PPU from Ageia is (according to the article I link below) capable of more than 10x more physics than a dual core CPU.
    An extra CPU core is still a general-purpose piece of hardware that has tons of extra silicon that does very little to help physics calculations. A PPU is designed for physics the way a GPU is designed for graphics...think about that...how much graphics can your computer do if you take out the graphics card and force it to use the CPU? Even if your CPU has 4 cores and runs at 3GHz (almost 6 times faster than a high-end GPU), it still can't compete with a simple integrated GPU when doing graphics.
    For more information, I've quoted one of my own previous posts (which referenced a previous post I made) here:
    Additionally, as this bit-tech article mentions, there could be applications for a PPU in scientific physics-type computations -- for those of us interested in the physics, and not the gaming, a PPU is a better choice than a GPU for certain. And, if Tom's hardware is correct, then a PPU is much much better than a run-of-the-mill multi-core CPU by itself.
  14. randosome
    randosome Banned
    17 Sep 2006
    EQC hit the nail on the head
    ATM games could use another core for physix, because they don't have the level of physix that a PPU can handle, once you start moving into the PPU realm the physics in the game rises sharply, and a CPU just cant handle it
    However, if we ever get games that make real use of a PPU - i have no idea
  15. Tyinsar
    26 Jul 2006
    The problem is that superiority does not automatically mean success <insert VHS / Beta or such example>. Without a decent market-share and game / app support <insert chicken / egg quip> this will die / is dying. I think it would be great if this took off and games got way more realistic and this became a common and reasonably inexpensive part of every game computer - but until then I'm putting my money back in my pocket.
  16. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    wasn't this already dead?
  17. Aankhen
    Aankhen What's a Dremel?
    15 Oct 2005
    Funny thing is that Tom's Hardware did an article (perhaps other sites did too, TH is the one I remember offhand) where even they had to grudgingly admit that a CPU can't handle the same sort of physics that a PhysX can. For example, in software mode, liquids are completely ignored; they aren't even rendered. In addition, as soon as you see a hint of proper cloth physics, the game comes to a grinding halt.
    PhysX is overpriced, and there aren't many reasons to buy it yet. But I don't believe a GPU or CPU can suffice in its place.
  18. DougEdey
    5 Jul 2005
    Sorry, but I've seen physics models produced that run at a few hundred FPS on a single core machine. These are engines produced by students and liquids and cloths render correctly.
  19. Cthippo
    Cthippo Can't mod my way out of a paper bag
    7 Aug 2005
    I still believe that the PPU is the correct answer, but conversely I think Ageia arreived too early with a product the market is not yet ready for. I've long been a believer in discreet cards for seperate tasks on the principal that somthing designed to do just one thing does that thing better than somthing designed to do many things. Perhaps if they had done a better job on the demo, produced somthing that truly stressed the PPU and would bring a conventional computer to it's knees they might have a better chance.
  20. DougEdey
    5 Jul 2005
    But at £140 you're reaching 8800GTS territory (only £35 more) and I'm sure that the GTS could do the job better.
Tags: Add Tags
