AGP 8x
Discussion in 'Hardware' started by Eviljaxx, 9 Sep 2004.
  1. Eviljaxx
    Eviljaxx What's a Dremel?
    2 Oct 2003
    Hey,
    I have recently just bought a new motherboard,
    AOpen AK77 - 600 Max
    I upgrade from the AOpen AK77 - 333, the 333 board is over 2 years old now and used AGP 4x and whats concerning me is that i have a GeForce FX 5800 Ultra and since i have used the new motherboard my 3Dmarks are now lower :confused: when yet when using 8x surly it should be faster....
    I have installed the 4 in 1 driver and the board is working 100% no issues no faults! any ideas why the sudden drop in 3Dmarks is around 2000 less
    Regards
  2. hilmana
    hilmana What's a Dremel?
    20 Aug 2004
    is it the same testing program??
  3. a9on87
    a9on87 ...
    2 Nov 2003
    Have you re-installed Windows since you upgraded the mobo, if not then I would recommend you do.
  4. Eviljaxx
    2 Oct 2003
    Hey yes its the same test program and i have done a full fresh install!
    All drivers are the same as how they use to be... Errrr
    I cant understand it to be honest
  5. Xen0phobiak
    Xen0phobiak SMEGHEADS!
    8 Aug 2002
    Whats your full system spec?
  6. Eviljaxx
    2 Oct 2003
    AMD Athlon 2600+ (333 FSB) Barton Core
    AOpen AK77-600 Max
    2 x 120 GB S-ATA RAID
    1024 DDR400 Kingston HyperX
    PNY GeForce FX 5800 Ultra
    Sound Blaster Audigy 2
  7. Xen0phobiak
    8 Aug 2002
    Install all the latest drivers and directx, it could just be becuase you now have something like anitaliasing or vsync turned on though ;)
  8. Eviljaxx
    2 Oct 2003
    No AA is off and all drivers are the same and installed i dont know what the problem is :wallbash:
