AGP -> PCI X
Discussion in 'Tech Support' started by cinek, 1 Sep 2007.
  1. cinek
    cinek What's a Dremel?
    1 Sep 2007
    is it possible to fit graphic card (PCI X) to AGP slot? if not,.... is there any way around it?
    I've got the phillips ls 2100.... (I know it's crap):wallbash:
  2. thestig198
    thestig198 Artificially Intelligent
    24 Jan 2004
    No.
    You probably mean PCI-E, PCI-X is something different (for servers or something?).
  3. cinek
    1 Sep 2007
    yeah I mean PCI-E sorry about that
    ....thx for the reply :)
  4. Sam0r
    Sam0r It's been a while
    24 Jun 2005
    No, buy a new motherboard ya cheapass :p
  5. wewe
    wewe What's a Dremel?
    16 Feb 2007
    no, it is possible to fit it, but you'd have to cut it yourself and then have a none working gfx card, yes buy a new motherboard cheapass
  6. severedhead
    severedhead What's a Dremel?
    19 Dec 2002
    The Philips Freeline LS2100 should have a PCI-E slot on the mobo. If its an MS-7046 mobo anyways.
    Unless its been changed at any point?
    Linky
  7. cinek
    1 Sep 2007
    I read that it has an agp slot..... I'll check anyway when I get back from the holiday :p
  8. mk-donald
    mk-donald bits and bobs
    2 Aug 2007
    FYI: AsRock make a few motherboards - with "DUAL" in their name - eg latest is 4CoreDual- SATA2 - which have DUAL video card interfaces/slots - ie an AGP (x8 speed, ie full) AND a PCI-E (only x4 speed, though seems only 1-5% difference versus x16 speed). Can only have ONE video card in, but gives one flexibility to use an existing/legacy AGP now, and swapout with a faster/greater PCI-E later.
  9. mattthegamer463
    26 Nov 2004
  10. C-Sniper
    C-Sniper Stop Trolling this space Ądmins!
    17 Jun 2007
    lol what a retard.
    if you want a combo motherboard get a Jetway 754GT-G-PV (or something like that) Its an AMD sckt 754 and has both AGP and PCI-E. This is what i am currently using and for what i need it is great.
  11. Delphium
    Delphium Eyefinity enabled
    18 Mar 2007
    However please note that any graphics card above the gforce 7 series for nvidia cards I beleive require a minimum of x8 PCI-E lanes.
    I painfully discovered this after having a dual interface board, when I upgraded from my 7800GS AGP to the 8800GTX PCI-E it would not work due to the lack of PCI-E lanes. So I ended up getting a new motherboard, ram and eventually a cpu.
    Though seeing as AGP is back from the dead, you still got options.
    mattthegamer463 - ROFL hard!!!
  12. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    8800GTS 320Mb works fine on Asrock 4coreDual-VSTA mobo (See my sig).
