scroll back a few pages, this topic came up not long ago. maybe a mod can search for it, if ya cant find it.
that would be funny. You want to try and set it up so there is a cd drive where the tapes are ment to go in.
any rackmount shop will sell them. However finding a rackmount shop is a mission in itself. Im after a 1U PSU in the uk so im also on the hunt. i will let you know if i find anywhere as they will be sold in the same place. but look for RACKMOUNT DISTRIBUTERS
here's the thread i mentioned earlier: http://forums.bit-tech.net/showthread.php?s=&threadid=7907 It was farther back than i thought 8)
they will sell you a 1u psu but wont sell you risers (unless you buy a case!) & the other place has VERY expensive shipping & surcharges..
W000t i 've found someone who sells them!!!! email: sales@sightsystems.co.uk Web: www.sightsystems.co.uk not on thier website but emailed them & its looking promising.. not got a price for them yet though..
Ok this may be dumb question but we shall see. Those pci risers, if you get a riser with 3 pci slots, and it only uses 1 itself can you add PCI slots to your motherboard. Eg. I have a motherboard with 3 PCI slots. If i bought a riser could i add 2 more and have 5 total PCI slots ???
no - they just change the angle of the card to be parallel with the mobo. you plug them into your existing pci slots.
