Graphics AGP upgrade
Discussion in 'Hardware' started by joey40949, 4 Dec 2009.
  1. joey40949
    joey40949 What's a Dremel?
    4 Dec 2009
    im looking to build a new i7 system as soon as i have the extra funds. but for now and time being im looking to upgrade my pci nvidia 5500 since some of my games lag to bad im looking for a agp card that is worth the upgrade but not expensive since im building new rig in next few mnths. here is my current rig
    amd athlon xp 2600+ cpu
    soyo dragon via kt600 motherboard
    1gb ram
    80gb hardrive
    nvidia 5500 pci
    430watt powersupply
  2. earlydoors
    earlydoors Minimodder
    12 May 2009
    what games you expecting to play ?
    welcome to the forums
  3. TheBlackSwordsMan
    TheBlackSwordsMan Far over the misty mountains cold
    16 Aug 2009
    What games do you play ?
  4. joey40949
    4 Dec 2009
    just need for speed battlefield call of duty and some others i was thinking of 7600gs or mabye a x1950 pro if i find one cheap enough a local shop near me have 6200agp 256mb for 50.00 but i didnt know how much improvement over my 5500
  5. roblikesbeer
    roblikesbeer Bindi's sex slave.
    23 Apr 2009
    The top two cards are the Ati HD 3850 and HD 4670, (£83 retail) both of which I've had in the last year and both easily capable of playable framerates at 1440x900, but that's with my rig which is a bit punchier than yours.
    See if you can get a X1950, that was a pretty awesome card.
  6. Krikkit
    21 Jan 2003
    I wouldn't bother tbh, it's money literally flushed down the drain now PCI-e has total market domination.
    If you do decide to upgrade I'd grab a card 2nd hand rather than new, helps reduce the waste.
  7. TheBlackSwordsMan
    16 Aug 2009
    AGP is available but PCI-E Superseded it since 2005-06, now the part list is short. What directx is Compatible with AGP ? I Remember hummmm Directx 9 in 2005 with my Gforce 4 Ti 4800Se :D
  8. Elton
    23 Jan 2009
    DX9 is compatible and so is DX10, but in all honesty, replace the old mobo and grab yourself a decent PCI-E GPU.
  9. TheBlackSwordsMan
    16 Aug 2009
    Affirmative. You dont have to buy an Expensive CPU or the Biggest GPU but Plz For the grace of God Change your RIG
  10. DaTLiTe
    DaTLiTe What's a Dremel?
    26 Apr 2009
    I would not bother with buying a new gfx card. Save your money to save up for a i7 system quicker. Or i would go on ebay and find a cheap thing as a stop gap, saves buying a new one only to get rid of it in a few months.
  11. TheBlackSwordsMan
    16 Aug 2009
    He dont have to buy an Expensive i7, Hes going to be fine with a Core 2 or a Quad.
  12. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    Recently i purchased an ATI 4650 AGP, and i thought it would be a breeze. Well its not when it comes to drivers.
    ATI catalyst for the 4000 series has no support for AGP products, ATI has a hotfix driver but it don't work.
    In the end i could only get the supplied driver on the disc to function under XP, so even with support for DX10 i cant make any use of it.
    Most pitiful IMO.
  13. roblikesbeer
    23 Apr 2009
    That's odd, the hotfix drivers have always worked on my 4670 AGP although I did have to install the latest version (9.11) manually as the provided installer is crap.
  14. Burnout21
    9 Sep 2005
    is that under vista or win7? Because mine installed fine under XP, but i miss out on DX10 support.
  15. TheBlackSwordsMan
    16 Aug 2009
    You can use it as a Sugar Spoon for you Tea :hip:
  16. Burnout21
    9 Sep 2005
    I am just happy its my second machine its in.
  17. roblikesbeer
    23 Apr 2009
    XP :rock:
  18. TheBlackSwordsMan
    16 Aug 2009
    I hope Win Millenium comeback soon, the Best OS Never made
