Graphics AGP vs. PCI-E
Discussion in 'Hardware' started by imkeller, 13 Aug 2006.
  1. imkeller
    imkeller What's a Dremel?
    8 Aug 2006
    PCI-E is better than AGP, right?
    i.e a 256mb agp graphics card will be worse than a 256mb pci-e graphics card?
    And AGP can't run in SLI right?
    Thanks, Keller
  2. atanum141
    22 Jul 2004
    Pci-e is better as it provides alot of extra badwith to the gpu but not only that but its bi-directional unlike agp.
    Also comparing a agp and pci-e gfx card depends on the card but usually pci-e outperforms the agp but not by huge differences.
    and yes agp cant run SLi or Corssfire due to the nature of how its designed.
    Also agp is a dead platform and isnt really buying a new card for it anymore, pci-e is its replacement and will last for a long time.
  3. imkeller
    8 Aug 2006
    K thx. Saved be before buying my new rig :D
    :D LOCKED :D
  4. rswami92
    rswami92 What's a Dremel?
    2 Feb 2007
    definitley pci-e is the way forward
  5. trig
    trig god's little mistake
    10 Aug 2006
    well, technically...pci-e 2.0 has been approved...lol
  6. Jipa
    5 Feb 2004
    The difference in performance between PCI-e and AGP cards from the same product is caused by the fact that the chip is either native AGP or PCI-e. The other version always needs some sort of chip to translate the data to the right connection. (or something.)
  7. imkeller
    8 Aug 2006
    Lol, I made this thread in august last year. I am now much wiser. It was nice to see it come up again tho.
