Windows AHHH All my Mozilla Bookmarks are GONE!!!! But not my homepage and extentions. HELP!!
Discussion in 'Software' started by tm36usa, 24 Jun 2005.
  1. tm36usa
    tm36usa What's a Dremel?
    21 Jan 2004
    Like the title says. I turned on my computer an hour ago to find that all my mozilla bookmarks are gone. IE's are still there but mozilla's are no where to be found. Help!
  2. ajack
    ajack rox
    17 Apr 2003
    Are they in
    C:\Documents and Settings\%user%\Application Data\Mozilla\Firefox\Profiles\<random>.default\bookmarks.html/bookmarks.bak?
    Take a look at this too :)
  3. tm36usa
    21 Jan 2004
    Nope, thats the first place i checked. Theres just one dat file named profile.dat, now im gonna go check out that link.
    EDIT: I will be sure and use that from now on, but it still doesnt bring my old ones back.
  4. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Do a search/Find Files for bookmarks.*, it would be most odd for Firefox to wipe both current and bak copies.
    Profile.dat? I don't have that file anywhere... :confused:
    edit: but you're using Mozilla. :duh:
  5. Fr4nk
    Fr4nk Tyrannosaurus Alan !
    12 Mar 2005
    Right this happened to me once :waah: I believe Firefox made a new profile with the default settings. so your orignal profile(your 1 with bookmark .etc) should safe
    just follow these instructions:
    1. go to start/run
    2. write "firefox.exe -profilemanager" (without qoutes) - press enter/click ok
    3. then a box like this should appear like this
    4. select your profile( if you don't witch one is yours just "trail and error" them :thumb:
    There all done you should have all your bookmarks.etc back now :thumb:
    ...frank
  6. tm36usa
    21 Jan 2004
    Thanks Frank for the great idea but no luck, there is only the defalt profile when I go there. Thanks tho
  7. Fr4nk
    12 Mar 2005
    Ahh... poo... you tried system restoring?
