Cooling AIO cooler choices @£40
Discussion in 'Hardware' started by Parge, 14 May 2015.
  1. Parge
    16 Jul 2010
    Hi folks.
    Its my friends birthday coming up. He's not a rich fellow, so I thought I'd buy him a new AIO cooler for his rig, since at the moment he's using the stock cooler. He's currently got a Athlon X3, but hopefully will upgrade next year to an 1155/1150, since he's been saving up for about two years for a new rig.
    I'm therefore looking for someting
    • About £40
    • AM3 and Intel compatible
    • PWM would be nice
    • 120mm (he doesn't have a case that will fit rads any larger)
    Scan have several nice options here:
    Corsair H60 - 2013 Factory Refurbished version
    Coolermaster Seidon
    MSI Dragon
    Antec Kuhler 650
    Personal preference would be either the Seidon or the H60, because I think the MSI Dragon looks a bit gash, and the Antec has a fan that cannot be changed, but what does everybody else reckon?
  2. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
    MSI's Dragon 90's tattoo logo is ****ing horrible and ruins there otherwise great products.
    Iv used a H60 in a friends build and its excellent for the money. Also looks the smartest.
    just make sure he dont use PWM with the pump. It has to be running at full power all the time otherwise you can fudge the pump.
  3. murraynt
    murraynt Well-Known Member
    6 Jun 2009
    I have been doing some research into sub £40 AIO coolers.
    Apparently the antec coolers are loud and then the fan can't be replaced.
    The H60 is a solid performer but not much better than the H55.
    The coolermaster has gotten some great reviews and preforms as well as the H80. I have seen some reliability issues on forums though. maybe the newer batches have addressed this.
    http://www.frostytech.com/articleview.cfm?articleid=2744&page=5
  4. Noob?
    Noob? New Member
    18 Oct 2009
    I'd personally go with the Seidon given its warranty is longer than the H60 at 2 years as opposed to 90 days for the latter.
    Otherwise I would have taken the H60.
  5. Parge
    16 Jul 2010
    Wow, the results for that Seidon are pretty incredible!
    EDIT: Though it seems that is with the fan at 2400rpm at which speed its pretty noisy.....
  6. Digerati
    Digerati Member
    19 Feb 2011
    Does he have heat problems? Note it is the case's responsibility to provide a sufficient supply of cool air flowing through the case. The CPU fan need only toss the CPU's heat into that flow and today's OEM coolers are fully capable of doing that even with mild to moderate overclocking.
    If not extreme overclocking and still overheating, I recommend upgrading his case cooling as that will help the rest of the components too.
    If he is not overheating, then I say buy him something that provides tangible performance gains, he can actually see, like more RAM.
  7. jinq-sea
    15 Oct 2012
    Without intending to be rude (and I note your considerable experience in the field of IT), I'm struggling to see how this is a relevant suggestion based upon the OP.
    If the OP's buddy is planning to go Intel -K series (and overclocking), using the stock cooler is simply daft. Also, remember, given the nature of this forum, it'll be based on an aesthetic viewpoint too :thumb:
    Moreover, the AMD stock coolers are, in my experience, loud, less-than-brilliant, and visually a bit naff. In the quest for quiet, an AIO is a champion choice for the money.
  8. GMC
    GMC Well-Known Member
    26 Jun 2010
    I'd say the H60, I'm using an H55 in my rig at the moment and it does a grand job.
  9. meandmymouth
    meandmymouth Well-Known Member
    15 Sep 2009
    I can't speak for refurbs, but I have been using an H60 for a while now in push-pull and it's coped fine with everything, although a bit loud with two fans.
  10. Ljs
    Ljs Well-Known Member
    4 Sep 2009
    Wow, very generous friend - I'd be lucky if any of mine even remember it's my birthday.
    Kudos.
  11. Digerati
    Digerati Member
    19 Feb 2011
    I don't mean to be rude either but you are basing your comments on your own "what if" that was never suggested.
    All we know is "hopefully" next year, he will get a new mobo. Nothing was said about overclocking. And while alternative cooling devices do look cool (no pun intended), we don't even know if he has a windowed case. And IMO, a tidy case interior with proper cable management provides great, professional aesthetics too.
    And true, we don't know how much RAM is in there now, but at least with RAM, depending on the starting point, you can install it and see instant performance gains, get instant gratification, instant better gaming, etc.
    If he is not overheating now, adding alternative cooling will NOT make his system more stable. It will not improve his gaming experience, his Internet performance or anything else.
    Once you install the AIO cooler, then it is out of sight out of mind - assuming he's like me and prefers to pay attention to what's happening on his monitors, instead of inside the case.
    As for noise, both Intel and AMD have heard the complaints and the new OEM coolers are much quieter than they were just few years ago. Plus a good case will do much to suppress fan noise, and for sure, AIO fans are not immune to fan noise (or worn bearings) either. Not to mention, as meandmymouth noted, not all that quiet either.
    And again, I am saying "what if" too - that is, "IF" this friend only has 4Gb or less now (and "IF" he has a 64-bit OS), adding more RAM will result in a better performing computer that can be seen from day one and then on. That's more power and who doesn't want "more power (arr arr arr!)". ;)
    Regardless, as Ljs points out, Parge's friend has a very generous friend.
  12. jinq-sea
    15 Oct 2012
    Ah but what you're missing is that I know Parge IRL, rather limiting the 'what if' factor ;)
    Additionally, I still don't understand how your reply is helping the OP? He said nothing about improving performance or anything like that - in fact, he merely posed the question 'which of these AIO coolers shall I buy my friend', not 'I'm buying my friend a birthday present, and I have looked at all of these AIO coolers, but I might just buy something completely different'.
    That said, I understand a) your desire to help in general; and b) that a RAM increase, inter alia, would provide a performance boost if RAM is limited at present. However, it doesn't help Parge choose which AIO to buy!
    FWIW, I'd go with the H60!
  13. Digerati
    Digerati Member
    19 Feb 2011
    :( He IS buying a gift for his friend's birthday. Is there some harm in suggesting something different? Something that is still computer related?
  14. Harlequin
    Harlequin Well-Known Member
    4 Jun 2004
    MSI is made by ASETEK - its pretty much a Corsair H55 with another badge on it.
    and I have one ;)
  15. Parge
    16 Jul 2010
    The reason I didn't suggest RAM is because he has 8GB already, and no more slots to fit additional RAM.
    Stock coolers are loud and suck for OCing, hence the upgrade there.
    After looking at the Seidon, it appears to look very 'cheap', so I think I'm going to go with the H60 in the end. I'll probably hook him up with some nice fans in push pull to replace the stock ones too!
  16. Digerati
    Digerati Member
    19 Feb 2011
    Great. Thanks for clarifying. And yeah, 8Gb is enough.
  17. SuperHans123
    SuperHans123 Well-Known Member
    27 Dec 2013
    Thanks for clearing that up for us.
  18. Harlequin
    4 Jun 2004
    btw my i7 2600k games at 4.3ghz @ 40 degree`s ;)
  19. modd1uk
    modd1uk Well-Known Member
    4 Sep 2006
    Did you decide which one Parge? Currently looking at these for a build too.
  20. Parge
    16 Jul 2010
    The H60 in the end mate. It just looks much smarter than the rest, and I've had very good experiences with Corsair kit in the past. With the non standard fan on the Kuhler, and the crappy looking logo on the MSI one, it came down to the Seidon or the H60. The Seidon has really good performance, but in the flesh looks really plasticky - you can see how they cut the corners, that's for sure.
    As an aside, for myself, I just picked up two H55s and two NZXT Kraken G10s from eBay for £70 all in, buyer even included two SST-FM93 92mm Silverstone fans with it that seem to be going for £9 a piece (though the cable isn't even braided - for £9 you'd expect it to be!).
    If they can get one GPU per eye working in VR, then my next Rig is going to be SLI. Its hard to go back to air cooling after water - I don't miss all the silly fiddling about, but I do miss those amazing temps - and this setup should hopefully be the best of both worlds.
