Guys, do you know someone who's really good in air bursh painting in UK? Someone who could paint a nice picture on a case? I found few googling it, but they ain't cheap.. like £250 and higher..
Ten years ago I knew a guy who charged £250 minimum back then... he did helmets for bikers mostly. dunx
Ello . You have Pm. As previous posts state airbrush by hand custom to high quality is expensive, but as i am so impressed with his work (wont mention here unless approved to do so), that id rather spend money on airbrushing than say getting new gfx card etc. I know hes busy, as hes doing my mouse, but not for 12 weeks, and i know for sure he will never be rushed, (obviously a good thing, quality important for him). However im sure detail can be reduced to suit a persons budget etc, i beleive he has this flexability, but to be honest its an ace investment and would last alot longer than a current gfx card.
Thanks for info. I'll try to get a quote on my stuff. But to be honest, if this would cost more than a £100 then I'm out. I beileve it is hard to do it yourself, but this kind of money is way out of my reach
Yeah, its a talent i sure would love to have. Pays a few thousand times more than what i get paid in my job . I think he said he bases full works on around 60 hours, so it actually works out reasonable value per hour i suppose , but still whacks them £££££ s up.
It might be worth checking out some r/c forums- there are a lot of talented 'novices' out there who paint their own shells- I'm sure a PC case side panel would be doable for them if you aren't after anything too complex or detailed ( depends what you had in mind ). Give the Candyman a shout, he does some great work & is UK based.
contact Steve Nunez www.stevenunez.com he is in NY but he has contacts all over so he might refer you to someone
Cheers guys, I'll take a look around then. Really don't want to spend hunderedsss of pounds on this. I will pay around £50-60 for powder caoting my case first, then again same amount for air brush would be pretty too much I guess.. especially I'm after really simple design. Thanks, I will check those out.
For a simple design ask at a local body shop, or maybe talk to a mobile paint repair technician ? I had a set of wheels sprayed for £160, large and complicated multi-spoke design... dunx
