air cooling O/C?
Discussion in 'Hardware' started by dmcm01, 11 Sep 2004.
  1. dmcm01
    dmcm01 Banned
    15 Aug 2004
    i have a intel pentium 2.4Ghz (not sure if its a prescott or a northwood)
    what would you recomend i overclock it too with just the standard intel HSF?
    my current stats are 2.4Ghz with 256MB of 166Mhz memory, i was thinking ov O/Cing it to 200Mhz but im not sure what i could/should do my Cpu too!
  2. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Didnt quite catch that...
    If u wanna overclock, just push it up bit by bit, it will overclock pretty well on the stocksink, you'd prolly get it to 2.8... maybe
  3. Froggy
    Froggy What's a Dremel?
    10 Jun 2003
    Overclock as far as you can go before you crash. After that, slow down a notch or to and test for stability. If your stable then your now overclocked. If your not stable then slow down again or increase the voltage a bit. If you haven't read it yet, take a look at the Hardware and Overclocking FAQ.
  4. dmcm01
    dmcm01 Banned
    15 Aug 2004
    yeah, i had it upto 2.89 but i wussed out and have it at 2.5 now, but its totally going back up........ :D thanks guys mucho helpo!
    btw my mobo calulates everything for you so i only know that the Mhz should be 166Mhz for a 2.9 etc. its not bad though because i know sod all about o/cing.....or maybe thats a bad thing :miffed:
  5. Froggy
    10 Jun 2003
    Let me guess its a Gigabyte Motherboard right? The easy mode really sucks. You might be able to get to 3Ghz or better depending on your ram and heatsink.
  6. dmcm01
    dmcm01 Banned
    15 Aug 2004
    it was going to be but the only one was for £215, but its an ASROCK p4s61 cpu + memory bundle: £130 from ebay :baby:
    twice i have taken it upto 2.9 and twice windows has failed to load with a BSOD :eyebrow: but ill keep playing!
