Modding Akasa 80mm Crystal Blue LED Fan
Discussion in 'Modding' started by :: Phat ::, 8 Jul 2002.
  1. Qbank
    Qbank What's a Dremel?
    19 Jun 2002
    iç think a 3000 mc wil do the trik
    anything between the 1000 and 3000
    the higher you go the focused they get
    lower the more spread the lighting is
  2. SCCorgan
    SCCorgan What's a Dremel?
    25 Jul 2002
    That is frikkin sweet....
    I was gonna just paint my fans blue but I'll just use those for the 80mm ones instead...I'll paint the others...
  3. inder
    inder Mr.Modtown
    17 Jul 2002
  4. Qbank
    19 Jun 2002
    sweeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeet
    i can't wait thil i got my 5 bleu ones
    thanks for the revieuw
  5. DrPsycho
    DrPsycho What's a Dremel?
    20 Jul 2002
  6. Qbank
    19 Jun 2002
    dgee geuse where he got that information
  7. DrPsycho
    20 Jul 2002
    :p
    :p credits to Qbank for this information :)
  8. lukemm
    lukemm What's a Dremel?
    5 May 2002
    The akasa fans are going for 4.95 on ebay.co.uk but plus 2.50 P+P still good value. i got a couple :) i will be unflashying them tho by replacing the LEDs.
  9. Qbank
    19 Jun 2002
    and wat do bleu leds cost...
  10. lukemm
    5 May 2002
  11. brumster
    brumster What's a Dremel?
    13 Jun 2002
    i just bought one of the akasa flashing blue LED fans to fit in my window blowhole. i too was unaware that they flashed when i ordered them, and when i tested it (couldnt mount it cos i dont have screws long enought to hold it thru 7mm acryllic) i found the unsynched stobe effect pretty cool, but the positioning less so. the worst thing i think is the fact that they are clearly visible, so i peeled the sticker off the other side and put it over the side with the LEDs in... unfortunately they still shine thru, but once i paint the plastic with silver paint (for reflectiveness) and then replace the sticker over the top of that it should look a bit better :)
    so... anyone have any ideas:
    a) where i can get 3/4" fan screws (pref. silver)
    b) what kind of paint would be most reflective (on the painted surface)
  12. brumster
    13 Jun 2002
    hmm.. having thought about it a bit, maybe the paint wont be necessary if i use a grille that has the centre part covered. i spotted the "roswell" grille at overclock.co.uk http://www.overclock.co.uk/moreinfo.php?id=722
    and i think those little slitty alien eyes might look pretty cool if flashing blue :lol:
    still no luck finding long fan screws tho...
  13. inder
    inder Mr.Modtown
    17 Jul 2002
    wow that grill is fantastic!
    for the screws, try any hardware shop i guess - not really anything special, and they will have longer sizes
  14. Qbank
    19 Jun 2002
    do they ship thath roswel grill to belgium ?
  15. inder
    inder Mr.Modtown
    17 Jul 2002
    yes they do, 42.08 Euro's for delivery though!
  16. Qbank
    19 Jun 2002
    thats wiuthout the price of the fan ?????????:eeek: :eeek: :eeek: :eeek: :eeek:
  17. inder
    inder Mr.Modtown
    17 Jul 2002
    yeh! :eeek:
    best bet would get someone to buy if for you (like someone in the UK, perhaps me...) and post it to you, would work out cheaper i guess
  18. brumster
    13 Jun 2002
  19. Seth
    Seth What's a Dremel?
    14 Mar 2002
    anyone have a link for the Antec Lighted LED Fans to buy in the u.s or canada?
  20. Qbank
    19 Jun 2002
