Akasa announce 22cm case fan
Discussion in 'Industry News' started by Guest-16, 14 Nov 2007.
  1. Guest-16
    Guest-16 Guest
    Attached PDF.
  2. Nexxo
    23 Oct 2001
    OMG IT'S HUUUGE!!! DESTROY IT! DESTROY IT BEFORE IT KILLS US ALL!!!
    :p
  3. sandys
    sandys Multimodder
    26 Mar 2006
    That would be ideal on the side of my Stacker.
  4. fathazza
    fathazza Freed on Probation
    20 May 2002
    i would have thought it would move more air tbh
  5. DougEdey
    5 Jul 2005
    If you took it out of a case, attached a long enough thin cable to it and a couple of stabilising fins, then we have found ETs mothership!
  6. sandys
    sandys Multimodder
    26 Mar 2006
    its only doing 600rpm, low noise, should push enough air to aid the dodgy mosfet coolers I've put on my 8800GTs :D my 7900 WC coolers will only do the RAM and GPU on the 8800, shame no one has stock yet :(
  7. Tyinsar
    Tyinsar 6 screens 1 card since Nov 17 2007
    26 Jul 2006
    I could do without the blue LEDs but otherwise :jawdrop::clap::thumb:
  8. Kerogaz
    Kerogaz What's a Dremel?
    22 Nov 2007
    So were can i buy it?
  9. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    you could hover on that thing :lol:
  10. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    Worse, is consider the fact that now you have <100 CFM spread over what, a 220x220mm area? Whereas before you had focussed cooling, now you have somewhat of a gentle breeze - which will get sucked away by all the other fans, FAST
  11. Guest-16
    Guest-16 Guest
    Im trying to dig out the email I got it in, but I cant find it :( I'm trying to find where they sell it!
  12. Kerogaz
    22 Nov 2007
    Okay, hmmm.... I wannna create a cooling on motherboard, something, that can blow like hell on memory, chipset and others... I dont wanna buy a new case, but upgrade existing one. A huge fan on left side of case- isnt it a perfect?
  13. sandys
    sandys Multimodder
    26 Mar 2006
    I sent them a mail on the day I heard about this, fan has not shown up yet anywhere :(
  14. lworbey
    lworbey What's a Dremel?
    23 Nov 2007
    Oh wow I saw these earlier actually, they are selling them at Maplin, they will be ideal for the case I want to build
  15. sandys
    sandys Multimodder
    26 Mar 2006
    Good find.
  16. Guest-16
    Guest-16 Guest
    Nice work! :)
    If someone buys one - grab a pic for us!
  17. Murdoc
    Murdoc Gas Mask..ZOMG
    25 Jul 2003
  18. lworbey
    23 Nov 2007
    Power Usage
    Having already decided to use these fans, I wanted to know the current usage for a temperature control circuit I'm making and thought it might be useful if anyone wanted to know!
    I emailed Akasa and they said the 22cm fan uses 0.28A or 280mA, might be useful to people as its quite a bit higher than smaller fans but reasonable considering the size!
  19. mutznutz
    mutznutz Cos Ive got a beard u label me evil
    18 Nov 2007
    I'll have to remeasure the inside of my case see if one of those bad boys will fit :)
  20. mctigger
    mctigger What's a Dremel?
    11 Feb 2007
    its HUGE!!!!! and i thought 12's were big lol
