Case Mod - In Progress Akasa Eclipse-62 modding
Discussion in 'Project Logs' started by Rodrigo Vicentini, 16 Jan 2012.
  1. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    I wish I could do that... Really beautiful! :thumb:
  2. nagyizom
    nagyizom Minimodder
    2 Jun 2008
    Oh maan! Your rose is beautiful!
  3. matiss
    matiss Minimodder
    24 Jun 2010
    Very nice craftsmanship with those cut outs. Looks fabulous.
    I´d say it´s a cutting disc like he showed before after heavy use.
  4. Darkwisdom
    Darkwisdom Level 99 Retro Nerd
    27 Aug 2011
    That looks absolutely fantastic. You certainly don't see this kind of work often, it's as unique as it is amazing.
  5. Ayrto
    Ayrto What's a Dremel?
    20 Jun 2007
    An Alice Madness Returns themed case with would look cool with those roses. Ok, so the game isn't perfect , but the artwork is nice.
  6. Waynio
    Waynio Relaxing
    20 Aug 2009
    Rodrigo :jawdrop: you absolutely rock mate :rock::clap: this is the kind of modding that seriously makes me say wow :D:dremel::rock::clap:.
    5 Stars + rep :)
    Masterful dremel work & the using different coloured acrylic for the right colours is a nice idea :).
    Rodrigo Vicentini likes this.
  7. Waynio
    Waynio Relaxing
    20 Aug 2009
    That is a worn down cutting disc I believe. To make intricate cuts like this you need worn down discs, it's highly skilled dremel work & the type I aspired to be as good as when I used to use a dremel :D.
  8. Rodrigo Vicentini
    Rodrigo Vicentini What's a Dremel?
    30 Apr 2006
    tks dude, I used various types of drill bits for dremel...
    tks dude =D
    what kind of bit is that?[/QUOTE]
    is a cutting disc showed before use.
    tks dude =D
    "made your own plexi" was not as expected, but as I found no other solution, I used that same ... but the end result was good
    tks bro :rock:
    tks dude, I'm glad that the friends of the MOD are enjoying my work :dremel::clap:
    tks dude = D this rose was complicated because it had many detelhes very small and I was afraid to screw up the side of the case, but the resoltado was better than I was imagining
    Tks dude with a little patience and the right tools I'm sure you do... :D:D:D
    tks dude =D:dremel::rock:
    tks dude :D
    That's right, they are cutting discs after use
    tks dude, it's true this kind of work, unfortunately, is not as present in the casemod, Now the focus is on hardware :sigh:
    tks dude = D
    I had not thought about it, really is a good idea for a theme, is noted here
    tks dude, I'm happy with the comment = :rock::rock::rock::rock::rock::rock: D
    that's right, this kind of cutting discs have to use very small, which makes the hard work
  9. Rodrigo Vicentini
    30 Apr 2006
    preparing the case for Campus Party Brazil 2012 =D
    case for a casemod
  10. Gtek
    Gtek Doesn't raise the bar; he IS the bar.
    10 Oct 2009
    Nice job! :thumb: Any chance of describing that plexi making in more detail? Is it like acrylic casting with some pigment?
  11. DallasDad
    DallasDad What's a Dremel?
    31 Jan 2012
    To the OP I felt it was worth registering to say what a briliant piece of work you have done well done :clap:
    I have just bought one of these cases on Ebay and this was the first site I found whilst researching what I was buying!
    Two of my three sons have been pestering me to build them a gaming PC for a while
    so I thought I would look for an alloy case as I bet they will want me to modify it.
    I have the idea of a fitting some mesh and a Mustang into to the side seeing as I have a Ford Mustang GT engine with a KB Supercharger in my MG ZT so it seemed a good subject.
    something like this
    And a teaser
    The engine is in this :)
