Hardware Akasa Freedom Tower CPU Cooler Review
Discussion in 'Article Discussion' started by Sifter3000, 27 Feb 2010.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    Too bad it's still far too high for my stock Compaq casing - my parents refuse to let me switch (casing). :(
  3. tonyd223
    tonyd223 king of nothing
    12 Nov 2009
    Old cases allow you to upgrade without the parents or wife knowing what you're doing - as long as the ventilation is ok...
  4. rickysio
    6 Jun 2009
    Huh?
    I've upgraded the internal components, but having a good HSF that doesn't use a backplate (I can't be arsed to dismantle everything) that is under 140mm is nearly impossible in Singapore.
  5. FelixTech
    FelixTech Robot
    12 Jun 2009
    Anyone else seeing a colour scheme match with the Fractal case? :)
  6. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    When I first saw this cooler I was quite impressed by its looks. Very simple but smart (if you can say that about a cooler). I like the fan housing especially. Its about time they used something better than a stupid and ugly piece of wire. On the whole I would definately consider this on my way to buy a Titan Fenrir.... Speaking of which, I just wish they would release a special blue edition.
  7. tank_rider
    tank_rider What's a Dremel?
    3 Feb 2005
    Another good value cooler from Akasa, they seem to have things pretty well sorted in the tower cpu cooler field! Might have to invest in one of these myself to replace an old akasa 965 :)
  8. Matticus
    Matticus ...
    23 Feb 2008
    Well done to Akasa. This almost looks sleek enough to make me want to rip out my watercooling and go back to air, almost.
  9. _Metal_Guitar_
    _Metal_Guitar_ What's a Dremel?
    16 Jun 2009
    Titan all the way, but this does look damn sharp!
  10. HandMadeAndroid
    HandMadeAndroid That's handy.
    18 Feb 2005
    I just purchased the Nero a few weeks ago from the same company, excellent value for money when trying to squeeze a few more £'s out the budget :D
  11. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
    Titan Fenrir still king!
    still a solid cooler and well priced i say.
  12. thewelshbrummie
    thewelshbrummie Minimodder
    29 Aug 2009
    Any reason LGA 1156 isn't mentioned? Looks like a good option, especially if mounting is easier than anything else on the market... but I won't be interested unless it supports the 1156 socket as it's my most likely upgrade path when I next upgrade in a few years time.
  13. rickysio
    6 Jun 2009
  14. Blanx3_Bytex
    Blanx3_Bytex What's a Dremel?
    3 Feb 2010
    Is there a reason the Gelid tranquilo isnt in the comparison graphs?
  15. Hazchem
    Hazchem Minimodder
    3 Dec 2004
    Damn this thing is beautiful! Definitely considering it when I upgrade my cooler.
  16. Adnoctum
    Adnoctum Kill_All_Humans
    27 Apr 2008
  17. Anfield
    Anfield Multimodder
    15 Jan 2010
    Intel will have new sockets in 2011 anyway, so if you don't want to upgrade now I would not worry too much about the cooling.
  18. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    I want!
  19. metalgearhathaway
    metalgearhathaway What's a Dremel?
    17 Feb 2010
    I brought one for my i7 920, but clocked at 3.2ghz.
    I also brought a xigmatek midgard case.
    Disappointed that under those clocked settings my max sustained prime test hit an almighty 85c.
    Would you expect it to be this hot at such a mild overclock?
    Any help from anyone dealing with similar kit would be great!
    I have all cooling fan bays filled, top bottom and additional in the dvd rom bays.
    I would have thought a higher clock and lower temp?
    Any help greatly appreciated!
Tags: Add Tags
