Hardware Akasa Galileo Review
Discussion in 'Article Discussion' started by Meanmotion, 14 Aug 2013.
  1. Meanmotion
    Meanmotion bleh Moderator
    16 Nov 2003
  2. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    'The second is a new fanless mini-ITX case, designed for slim-type mini-ITX motherboards, called the Galileo. Then, following on from the Euler, the Galileo is a slightly longer, more expensive case, which is designed from the ground up to be as skinny as possible.'
    This doesn't make sense, did you mean to end the first sentence with 'Euler'?
  3. Combatus
    16 Feb 2009
    We've tweaked this now so it makes more sense :D
  4. SchizoFrog
    5 May 2009
    A, yes indeed it does. Thanks. :)
  5. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    I'm sure that one day, an article will be posted on this site that doesn't contain a single typo or error. It'll be awesome because we'll then have discussions about the stuff being reviewed rather than proof reading the articles :D
    I think this case is a nice idea but looks really dull: even though the build quality seems top-notch, it just isn't very stylish, imo. Also, I'd like to see some front USB ports hidden behind a cover or something, so that they don't stick out like a sore thumb but are still available if required.
Tags: Add Tags
