Hardware Akasa Nero S CPU Cooler Review
Discussion in 'Article Discussion' started by Claave, 22 Mar 2010.
  1. Claave
    Claave You Rebel scum
    29 Nov 2008
  2. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    I keep wondering why these manufacturers can't just group all 4 pipes together and leave paperthin thickness aluminium between them. Just bend the outer tubes, and it should solve the issue of no transfer due to HSF being too small.
    And I predict a series of comments about how the V-X performs (or underperforms, rather) again. :S
  3. lacuna
    lacuna Minimodder
    9 Aug 2004
    touching.
  4. dec
    dec [blank space]
    10 Jan 2009
    touche
  5. DarkHarlequin
    DarkHarlequin Padowan Learner
    13 Oct 2009
    toupée
  6. TWeaK
    TWeaK Minimodder
    28 Jan 2010
    I get the feeling that the AMD mounting mechanism is a bit naff by today's standards. It seems that any cooler that uses the latch to secure it underperforms on AM3 compaired to other sockets.
  7. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    I would have liked to see a direct comparison between this and the Akasa Freedom Tower. Especially on LGA775, although I understand us poor old Core 2 Duo owners are being put out to pasture.
  8. Baz
    Baz I work for Corsair
    13 Jan 2005
    :duh: edited so we don't touch you quite so much.
  9. MaverickWill
    MaverickWill Dirty CPC Mackem
    26 Apr 2009
    I wish you-know-who would touch me...
  10. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    No offence intended to Bit-Tech as they do not make these coolers but these reviews are getting to the point of generic. For a few degrees here and there give or take £5-£10. Is it really that important? When building a system that is likely to be costing you in excess of £600, does £10 really break the budget? The whole recent batch of CPU coolers virtually all look the same too, metal plates with what looks to be, even if it isn't, a standard case fan attached. What happened to the good old days when CPU coolers also looked cool as well as kept your CPU cool? - (Although I do like the Special Edition of the Titan Fenrir, I just wish they did a blue version).
    Bit-Tech - Do you have to draw straws to see who gets the pleasure of these tedious tests?
  11. Combatus
    16 Feb 2009
    I wish I didn't :eyebrow::jawdrop:
  12. MaverickWill
    26 Apr 2009
    :waah::waah::waah:
    On a related note (because I kinda have to), I liked the Nero, so big points to Akasa for this! Looks to be a strong contender for a while on the big-boy socket!
  13. Cobalt
    Cobalt What's a Dremel?
    24 Feb 2006
    Notice that all of the coolers perform worse at idle on the AMD tests. That's because Bit is using a 1.6V core compared to 1.3V/1.35V of the Intel systems so its probably got a higher thermal output when not loaded. The load figures are comparable though; its just that the Intel graphs use a different scale.
Tags: Add Tags
