Cases Akasa Venom Toxic + Voodoo
Discussion in 'Hardware' started by Wozza365, 31 Jan 2012.
  1. Wozza365
    Wozza365 What's a Dremel?
    26 Jan 2012
    I bought this PC from pcspecialist UK who build custom PCs great quality would definitely recommend them to anyone
    My specs include:
    FX8150
    Palit GTX570
    8GB HyperX 1600MHz
    120GB Intel 320 SSD
    Corsair TX850
    When I first saw this case, I pretty much fell in love with it, I hadn' really even looked into it much, mainly because there is very little info on the internet, but I went with it and also got the matching CPU cooler
    Cooling wise the case is very impressive and I get pretty good temps, even with all the fans on minimum via the fan controller
    The large bay things at the front have a great lock in feature, saving me from screwing everything in, these are also bright yellow and make the inside of the case look great, the hard drive bays are very good and also have the option to natively use 2.5” HDDs, rather than brackets, only problem is the cables behind the cage causing my HDDs to pop out
    The front fan is 23cm and has white LED, this may seem a terrible idea, but is not as bad as some might think although I've found this fan pretty poor in shifting air, even at max, a good thing though is that this has a fan filter on it, it would have been impossible to find a fan filter otherwise, the bottom fan slot also has a filter built in which also saves some extra case, this slot can take up to 14cm although I currently have an old 80mm fan sitting there for extra intake. The PSU also has an easily removable filter which may turn out to be a godsend in a few months or years. The back and top fan are both pretty good fans, although the yellow one should have S-Flow built in to it, I think the front and top 23cm fans should also be yellow to match the case.
    I haven't had any problems with the fan controller that’s built in, although I'm not sure if its putting the fans to their full potential, its not overly important though and I have an extra fan controller now for any new fans (will be getting 4 yellow fans on the side). The other parts to the top are good and haven't caused any problems, other than the USB3 which requires a cable to run from the back to the front, I'm unsure why. The little mat bit is a great idea and is a great place to keep all my memory sticks
    Cable management is great on this case and from the front I have very little wire showing, but I’m thinking a few extra millimetres at the back definitely wouldn't go a miss, the rubber grommets are a very good idea, and also down a lot of the sides on the edge of the metal, its curved and allows for a wire to fit perfectly and hidden from view.
    PSU looks pretty comfy, no problems there...
    The PCI slots have easily removable switches although for some reason PCS didn’t install these and used screws instead, not sure why, but it may be a project for me later on.
    The venom logo on the other side is a great feature, its just a shame I can't see more of it at the moment.
    To install new DVD drives or fan controllers, its a very confusing process, you must first, remove the front, by pulling from the bottom then top, then you must remove the mesh covers from this part to allow the device to be seen. Then you must pull off these metal parts, which are pretty tough to get off and aren't really made to be put back on, at least that’s what it seems like. One of the mesh panels also has the 3.5” adapter thing and also the tray behind it
    This case, when working it out is amazing value for money, and with a few small changes they could easily sell this for £200+
    Cooler
    The voodoo cooler fits in perfectly with the theme of this case and looks great as well, it has 2 12cm Viper fans and they cool excellently, I've read reviews and there are a lot of coolers that are better, but for the price, its in a higher rank than it should be.
    My CPU idles at around 33-34c although its not really idle as I have multiple programs open including Firefox and a video file, this decreases when its in proper idle, and also, all my fans are on minimum settings on the fan controller and the cooler is set to 'silent' mode. So all around pretty impressive, I thought it best mention that by the looks of it, this case should be able to squeeze in a 14cm cooler such as the NH-D14
    Here is all my pics, lots of them
    http://imageshack.us/g/215/dscf0123w.jpg/
    http://imageshack.us/g/840/dscf0174t.jpg/
    http://imageshack.us/g/822/dscf0098vy.jpg/
    Sorry if the pics are often the same, my camera screen isnt great and makes the pics look worse than they often are, meaning i take them again
  2. Wozza365
    26 Jan 2012
    hope everyone enjoys this review, if you are looking for a top notch case at good value this is definitely one to consider
  3. guess_who
    guess_who What's a Dremel?
    4 Feb 2012
    hi mate,
    Nice looking gaming case,
    Looks like its good pretty good customisation.
    I wonder if you can mod in a three fan rad in the top?
  4. Wozza365
    26 Jan 2012
    Good news on the CPU cooler (and partially case) - just did prime 95 for half hour and got some great temps
    on turbo mode in the ASUS Suite, the CPU temps hovered between 47-48c the whole time, this was also in a warm room with the heating on and windows shut, I'm gonna do another test when the room is a bit cooler
  5. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    Now crank that 8150 to 4Ghz. They love it! I can hit 5ghz on this 8120 with little difficulty, on air; 3.8 should be more than reasonable for you, not much above stock voltage, too!
  6. Wozza365
    26 Jan 2012
    I'm not too sure about triple rad up top but i know a double works, i havent had a chance to open the top bit for where the rad would go but ill have a look if i can get it open
    and I was considering OCing it to 4.5GHz as that is what PCSpecialist offers for free (if i do it over the phone i keep my warranty..)
  7. .//TuNdRa
    12 Feb 2011
    It's not that hard with the FX8xxx if you're only looking to up the CPU speed, simply increase CPU PLL and CPU vCore and then nudge the multiplier upwards a few notches. Bonus is; Cool & Quiet still takes effect, so you're not stuck idling at 4Ghz and such.
    It's if you're looking to really squeeze performance out that you have to throw that approach out of the window, skew the base FSB, then go Apesh!t on the voltages & multipliers.
  8. Wozza365
    26 Jan 2012
    i just dont want to ruin my warranty thats why im doing it over the phone
  9. guess_who
    4 Feb 2012
    sounds like ya getting good temps, is that due to the case and cooler or does the dulldozer run pretty cool anyway?
  10. Wozza365
    26 Jan 2012
    bit of both, the case and cooler do a decent job but i think the processor itself stays pretty cool
  11. guess_who
    4 Feb 2012
    sounds good mate,
    I'd certainly get some case mods going.
    !!!!!AKASA SHOULD DO A WINDOW PANEL!!!!!
    I'd buy one then!!!!
  12. Wozza365
    26 Jan 2012
    yeh i did actually send them an email about that, would love one of them although would need 4x12cm fan slots still
  13. guess_who
    4 Feb 2012
    could always mod ya own fan slots in :)
  14. Wozza365
    26 Jan 2012
    i could, but i ave the smallest amount of experience in that kind of thing
