Hardware Akasa X4 Cooler Review
Discussion in 'Article Discussion' started by Sifter3000, 13 Dec 2009.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    Bar colour error for Tuniq Tower 120 Extreme (high speed) in Socket AM2+ delta T chart.
  3. scrimple3D
    scrimple3D What's a Dremel?
    29 Apr 2009
    I'm surprised that no figures are included for either version of the Freezer 7 Pro especially after mentioning it a few times.
  4. barndoor101
    barndoor101 Bring back the demote thread!
    25 Oct 2009
    how did this one compare to the titan skalli?
  5. TWeaK
    TWeaK Guest
    What I'd like to know is why it isn't as good. Is it because of the push-pin mounting? Is it the design of the baseplate? The thickness of the heatpipes? The size of the fan?
    Obviously these are hard things to measure - perhaps impossible without modding, which isn't really appropriate for a product review. However, it would be nice to see some attempt at explaining this, even if it just amounts to speculation - sometimes more of the writer's opinion could be welcome. At the very least, it might spark discussion.
  6. MaverickWill
    MaverickWill Dirty CPC Mackem
    26 Apr 2009
    I'd bet the baseplate was at fault. Similarly-designed coolers with direct contact have done much better than this. The 92mm fan probably didn't help.
  7. SteveU
    SteveU Minimodder
    19 Jun 2009
    Will be keeping my Freezer 7 Pro bolted to my E8400 for now then.
  8. javaman
    javaman May irritate Eyes
    10 May 2009
    Why do so many coolers perform badly on AM2+? is it because AMD chips run so much hotter?
  9. Xir
    Xir Modder
    26 Apr 2006
    As you compare a lot af the cheaper coolers to the Arctic Cooling Freezer 7 Pro, why isn't that in the charts?
  10. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    You spend the first page comparing it to the Freezer 7 Pro, then don't bother to include the Freezer 7 in the comparison graphs. A tad remiss?
  11. l3v1ck
    23 Apr 2009
    Okay, The freezer 7 Pro is old, but Rev 2 is new and fits all three sockets, that should have been tested.
Tags: Add Tags
