Scratch Build – In Progress "Al - 13 - "Duplicity" Big update, getting shiny, nearly finished!
Discussion in 'Project Logs' started by ShinyAli, 14 Sep 2012.
  1. fr0Zen
    fr0Zen back i guess
    25 Oct 2011
    I love the silverstone inspired hot air rises design element. The execution is over the top and overall quality:thumb:
  2. ShinyAli
    ShinyAli What's a Dremel?
    14 Sep 2012
    Thank you for all your comments, much appreciated :thumb:
    As you get near the end of a build and you stop and take a step back to look at what you have made I often find it surprising how it all happened, sometimes I can't really remember making some parts, it's like an endless reverie :cooldude:
  3. kelmannen
    kelmannen What's a Dremel?
    5 Feb 2011
    really great build! and you are right about the conceptual sketches, the first thought i had was "ooh another alubar build, giant case no sides or really messy... but i was wrong! and i really like this chassis :rock: :rock: :thumb:
    A suggestion that i have is however that you dont put a knob that points out of the chassis side, i think it would look wrong! try to cut out a rectangular hole in the side and make a little handle thats folds out when you press at the top/bottom of the cutout, the turning point on the inside so all you'll see on the outside will be a flat surface.
    kinda hard to explain, english is not my native language.... >.<
  4. Mosquito
    Mosquito Minimodder
    24 Mar 2011
    I agree with that 100%.
    Great work :thumb:
  5. ShinyAli
    14 Sep 2012
    Hi kelmannen, Your right, no sticking out door knobs :nono: As the doors are held shut by magnets and a steel plate I have an idea to use some even stronger Neodymium magnets set into a detachable door knob to pull the door open, It's an idea I had a while ago but forgot about...I need more magnets :rolleyes:
  6. kelmannen
    5 Feb 2011
    good, i'm relived now :)
  7. Waynio
    Waynio Relaxing
    20 Aug 2009
    Really nice creation ShinyAli, looks a perfect layout & I'd say if not the best then at least amongst the best layouts I've seen for a regular ish form of case, love the way you access the insides too, wish I had space to add gas struts now, it's doubtful but of course I'll double check, still not totally sure how I'll be mounting mine, was going to go with a plug in place type system but gas struts are pretty sweet. :D
    Looks awesome too. :)
    Sure had no idea you was beta brain too. :D
  8. doveman
    doveman What's a Dremel?
    7 Nov 2012
    Aw man, who nicked all your photos. I was going to refer to them for my own build.
